path: root/configs/sandbox_noblk_defconfig
2018-02-23configs: Re-sync with CONFIG_DISTRO_DEFAULTSTom Rini
A number of platforms include config_distro_defaults.h but do not enable CONFIG_DISTRO_DEFAULTS. As they plainly intended to, set that flag and re-sync config files. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-27usb: kbd: Set a default polling mechanism for USB keyboardBin Meng
The choice of "USB keyboard polling" cannot be optional as without one mechanism being set, it just doesn't work. Set the default one to CONFIG_SYS_USB_EVENT_POLL. Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-16bootstage: Drop unused optionsSimon Glass
The CONFIG_BOOTSTAGE_USER_COUNT option is no-longer needed since we can now support any number of user IDs. Also BOOTSTAGE_ID_COUNT is not needed now. Drop these unused options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-05bootstage: Change CONFIG_BOOTSTAGE_USER_COUNT to an intSimon Glass
There is no good read to make this hex, and integer is more natural for this type of setting. Update it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_IDE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IDE Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_CALLBACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_CALLBACK Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-15sandbox_noblk_defconfig: disable CONFIG_GENERIC_MMCMasahiro Yamada
As commit 54925327fa11 ("mmc: move CONFIG_GENERIC_MMC to Kconfig") addressed, this is one of the last weird defconfigs that define CONFIG_GENERIC_MMC without CONFIG_MMC. Now I took a closer look at this. Given that neither CONFIG_CMD_MMC nor CONFIG_MMC is set for this defconfig, CONFIG_GENERIC_MMC should be disabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-10power: rk808: rename to rk8xxJacob Chen
Since this driver can be used for rk8xx series pmic, let's rename rk808 to rk8xx, to make it clear. Configs parts are done by sed -i "s/RK808/RK8XX/g" `grep RK808 -lr ./` Signed-off-by: Jacob Chen <jacob-chen@iotwrt.com>
2017-05-09dm: test: Add tests for the generic PHY uclassJean-Jacques Hiblot
Those tests check: - the ability for a phy-user to get a phy based on its name or its index - the ability of a phy device (provider) to manage multiple ports - the ability to perform operations on the phy (init,deinit,on,off) - the behavior of the uclass when optional operations are not implemented Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-30fs: Kconfig: Add a separate option for FS_CRAMFSSimon Glass
Rather than using CMD_CRAMFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CRAMFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CRAMFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CRAMFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Kconfig: Add a separate config for FS_CBFSSimon Glass
Rather than using CMD_CBFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CBFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CBFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CBFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CBFS on SYS_COREBOOT] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-27dm: sandbox: pwm: Add a basic pwm testSimon Glass
Unfortunately a test for the PWM uclass was not included when it was submitted. This was noticed when trying to add more functionality: http://patchwork.ozlabs.org/patch/748172/ Add a simple test to get us started. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-14dm: led: Add support for blinking LEDsSimon Glass
Allow LEDs to be blinked if the driver supports it. Enable this for sandbox so that the tests run. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Ziping Chen <techping.chan@gmail.com>
2017-03-17configs: move CMD_MD5SUM definition to defconfigsAndre Przywara
Boards with an apparent need for the md5sum command had the connected config symbol defined in their board header file. Move this over to the respective defconfig files now that md5sum is configured via Kconfig. (This is a manual effort, which differs from moveconfig.py, not sure who is right here. Boards except sandbox loose the md5sum command with moveconfig.py, though it was explicitly mentioned in their config.h's) Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: migrate stih410-b2260] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-28disk: convert CONFIG_AMIGA_PARTITION to KconfigPatrick Delaunay
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-11dm: blk: Enable CONFIG_BLK if DM_MMC is enabledSimon Glass
To speed up conversion to CONFIG_BLK, enable it by default when DM_MMC is enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: rk3036: pinctrl: fix config symbol namingHeiko Stübner
Rockchip socs are always named rkxxxx in all places, as also shown by the naming of the rk3036 pinctrl file itself. Therefore also name the config symbol according to this scheme. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: rk3288: pinctrl: fix config symbol namingHeiko Stübner
The rk3288 pinctrl is very specific to this soc, so should not hog the generic rockchip naming. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: sandbox: Add a board for sandbox without CONFIG_BLKSimon Glass
While the driver-model block device support is in progress, it is useful to build sandbox both with and without CONFIG_BLK. Add a separate board for the latter. Signed-off-by: Simon Glass <sjg@chromium.org>
