path: root/configs/sandbox_defconfig
2019-06-21configs: Resync with savedefconfigTom Rini
2019-06-14net: Convert CONFIG_IP_DEFRAG to KconfigMarek Vasut
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers and whitelist. This patch is a follow-up on a patch by Christian Gmeiner with the added config/header/whitelist updates. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-04-23sandbox: Move pre-console buffer out of the way of tracingSimon Glass
These two buffers currently conflict if tracing is enabled. Move the pre-console buffer and update the documentation. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-04-11sandbox: Enable fdtdec testsThierry Reding
Enable fdtdec tests on sandbox configurations so that they can be run to validate the fdtdec implementation. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-01rockchip: defconfig: Clean the unused pinctrl configDavid Wu
If we used the pinctrl-rockchip driver, these config is not needed, so remove them. Signed-off-by: David Wu <david.wu@rock-chips.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2019-01-19configs: Resync with savedefconfigTom Rini
2019-01-14test: bootcount: add bootcount-uclass testPhilipp Tomsich
Add a test for the bootcount uclass, which uses the RTC bootcount backend (i.e. drivers/bootcount/rtc.c is implictly also tested). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-13sandbox: Increase the pre-relocation memorySimon Glass
This is close to full now, so increase it to avoid problems with adding more devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-12-07test: dma: add dma-uclass testGrygorii Strashko
Add a sandbox DMA driver implementation (provider) and corresponding DM test. Reviewed-by: Tom Rini <trini@konsulko.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Álvaro Fernández Rojas <noltari@gmail.com>
2018-12-06dm: Add Hardware Spinlock classBenjamin Gaignard
This is uclass for Hardware Spinlocks. It implements two mandatory operations: lock and unlock and one optional relax operation. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
2018-12-03configs: sandbox: enable padding pss for rsa signaturePhilippe Reynes
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-09sandbox: Add a debug UARTSimon Glass
Add support for the debug UART so that sandbox provides build testing for this feature. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-09-30Merge git://git.denx.de/u-boot-dmTom Rini
2018-09-29Merge branch 'master' of git://git.denx.de/u-boot-videoTom Rini
2018-09-29test: Add tests for board uclassMario Six
Add tests for the new board uclass. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-28configs: sandbox: add onewire w1 and sandbox eepromEugen Hristev
To be able to test Dallas onewire protocol and one wire eeproms driver and subsystem, add in sandbox defconfig the drivers' config. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28video_osd: Add osd sandbox driver and testsMario Six
Add sandbox driver and tests for the new OSD uclass. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-09-23efi: sandbox: Enable selftest commandSimon Glass
Enable this for sandbox since it almost passes now. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-08-21cmd: Add bind/unbind commands to bind a device to a driver from the command lineJean-Jacques Hiblot
In some cases it can be useful to be able to bind a device to a driver from the command line. The obvious example is for versatile devices such as USB gadget. Another use case is when the devices are not yet ready at startup and require some setup before the drivers are bound (ex: FPGA which bitsream is fetched from a mass storage or ethernet) usage example: bind usb_dev_generic 0 usb_ether unbind usb_dev_generic 0 usb_ether or unbind eth 1 bind /ocp/omap_dwc3@48380000/usb@48390000 usb_ether unbind /ocp/omap_dwc3@48380000/usb@48390000 Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2018-08-11sandbox: Add and build AXI bus and deviceMario Six
Add test AXI drivers to the sandbox. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-28sandbox: compile both TPM stack versions and driversMiquel Raynal
Now that TPMv1 and TPMv2 can be compiled at the same time, let's compile them both with Sandbox as well as both drivers (and, it is already implied in Kconfig: both commands). Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-07-19drivers: smem: sandboxRamon Fried
Add Sandbox driver for SMEM. mostly stub operations. Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25configs: add TPMv2.x support in SandboxMiquel Raynal
Enable the Sandbox TPMv2 driver in all possible configurations. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-05-18sandbox: Enable MC34708 PMIC supportLukasz Majewski
This MC34708 PMIC is somewhat special - it used single transfers (R/W) with 3 bytes size - up till now U-Boot's PMICs only used 1 byte. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-13SystemACE: RemoveTom Rini
This driver is no longer used on any supported platform in U-Boot and there is no interest in maintaining it further from people that have used it historically. Cc: Simon Glass <sjg@chromium.org> Cc: Michal Simek <michal.simek@xilinx.com> c: Alexey Brodkin <alexey.brodkin@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2018-02-08block: Migrate SystemACE chip to KconfigTom Rini
Migrate the base and sub-options to Kconfig. Note that we only enable this in the base sandbox config now. Cc: Alexey Brodkin <alexey.brodkin@gmail.com> Cc: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Tom Rini <trini@konsulko.com> --- Is this driver still used anywhere? It's fishy that it's only enabled in sandbox anymore.
2018-02-03log: Add a way to log error-return valuesSimon Glass
When functions return an error it propagates up the stack to the point where it is reported. Often the error code provides enough information about the root cause of the error that this is obvious what went wrong. However in some cases the error may be hard to trace. For example if a driver uses several devices to perform an operation, it may not be obvious which one failed. Add a log_ret() macro to help with this. This can be used to wrap any error-return value. The logging system will then output a log record when the original error is generated, making it easy to trace the call stack of the error. This macro can significantly impact code size, so its use is controlled by a Kconfig option, which is enabled for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-12-07log: sandbox: Enable loggingSimon Glass
Enable all logging features on sandbox so that the tests can be run. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-12-07sandbox: Adjust pre-console address to avoid conflictSimon Glass
We cannot use sandbox memory at 0 since other things use memory at that address. Move it up out of the way. Note that the pre-console buffer is currently disabled with sandbox, but this change will avoid confusion if it is manually enabled. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-10-03sandbox: Enable btrfs supportTom Rini
For better test coverage, enable btrfs. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-27usb: kbd: Set a default polling mechanism for USB keyboardBin Meng
The choice of "USB keyboard polling" cannot be optional as without one mechanism being set, it just doesn't work. Set the default one to CONFIG_SYS_USB_EVENT_POLL. Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-17Merge git://git.denx.de/u-boot-x86Tom Rini
2017-09-16bootstage: Drop unused optionsSimon Glass
The CONFIG_BOOTSTAGE_USER_COUNT option is no-longer needed since we can now support any number of user IDs. Also BOOTSTAGE_ID_COUNT is not needed now. Drop these unused options. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-15Merge git://git.denx.de/u-boot-fdtTom Rini
2017-09-15config: sandbox: Add unit testsPantelis Antoniou
Add unit tests for sandbox default config. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-09-14add pytests for 'gpt rename' and 'gpt swap'Alison Chaiken
Add unit tests for the 'gpt rename' and 'gpt swap' commands that rely on the block device created by test/py/make_test_disk.py. Add CONFIG_CMD_GPT_RENAME to the sandbox_defconfig. Remove the testdisk.raw test device at the end of the tests. Signed-off-by: Alison Chaiken <alison@peloton-tech.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-28sandbox: Enable NVMe driver for build testingBin Meng
This enables NVMe driver on sandbox for build testing. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
