path: root/configs/sandbox_defconfig
2016-07-27Add a power domain framework/uclassStephen Warren
Many SoCs allow power to be applied to or removed from portions of the SoC (power domains). This may be used to save power. This API provides the means to control such power management hardware. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: rk3036: pinctrl: fix config symbol namingHeiko Stübner
Rockchip socs are always named rkxxxx in all places, as also shown by the naming of the rk3036 pinctrl file itself. Therefore also name the config symbol according to this scheme. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: rk3288: pinctrl: fix config symbol namingHeiko Stübner
The rk3288 pinctrl is very specific to this soc, so should not hog the generic rockchip naming. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25sandbox: Migrate CONFIG_I2C_EEPROMTom Rini
Most users of CONFIG_I2C_EEPROM were migrated to defconfig a while ago, but sandbox was skipped. Leave it off for sandbox_spl where it does not build, but does not need to be either. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-11dm: sandbox: Convert to use CONFIG_CMD_MMC_OPSSimon Glass
Update the sandbox MMC emulation to use driver model for MMC operations. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-19reset: implement a reset testStephen Warren
This adds a sandbox reset implementation (provider), a test client device, instantiates them both from Sandbox's DT, and adds a DM test that excercises everything. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26mailbox: implement a sandbox testStephen Warren
This adds a sandbox mailbox implementation (provider), a test client device, instantiates them both from Sandbox's DT, and adds a DM test that excercises everything. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> # v1
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-23config: sandbox: enable qfw and cmd_qfw for testingMiao Yan
This patch enables qfw and cmd_qfw on sandbox for build coverage test Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-17dm: sandbox: mmc: Enable building MMC code for sandboxSimon Glass
Enable building the MMC code for sandbox. This increases build coverage for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-04-15sandbox: Enable many more commandsTom Rini
- Set CONFIG_SYS_CACHELINE_SIZE to ARCH_DMA_MINALIGN as that should be good enough. - Make <asm/io.h> include <asm/types.h> like other arches do - Enable many many more drivers in sandbox_defconfig so that we can get more build-time testing on this platform. Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-01spmi: Add sandbox test driverMateusz Kulikowski
This patch adds emulated spmi bus controller with part of pm8916 pmic on it to sandbox and tests validating SPMI uclass. Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-17dm: sandbox: Switch over to use DM for block devicesSimon Glass
Now that the drivers used by sandbox support CONFIG_BLK, we can switch sandbox over to use driver model for block devices. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-02-26sandbox: Enable the early timerSimon Glass
Enable this so that tracing works with sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-02-26sandbox: Correct ordering of defconfigSimon Glass
This has got out of order: fix it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-30video: sandbox: Enable truetype fonts for sandboxSimon Glass
Enable this feature so that truetype fonts can be used on the sandbox console. Update the tests to select the normal/rotated console when needed. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-30video kconfig console_normalSimon Glass
Signed-off-by: Simon Glass <sjg@chromium.org> [agust: rebased on current master] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-20dm: video: test: Add tests for rotated consolesSimon Glass
Test that text is displayed correctly when the console is rotated. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20dm: video: sandbox: Convert sandbox to use driver model for videoSimon Glass
Now that driver model support is available, convert sandbox over to use it. We can remove a few of the special hooks that sandbox currently has. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-20sandbox: Move CONFIG_VIDEO_SANDBOX_SDL to KconfigSimon Glass
Move this option to Kconfig. This is quite simple as only sandbox uses the driver. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01dm: core: Add SPL Kconfig for REGMAP and SYSCONhuang lin
Add SPL Kconfig for REGMAP and SYSCON, so REGMAP and SYSCON can remove from SPL stage. Signed-off-by: Lin Huang <hl@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-12-01dm: pci: Disable PCI compatibility functions by defaultSimon Glass
We eventually need to drop the compatibility functions for driver model. As a first step, create a configuration option to enable them and hide them when the option is disabled. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19sandbox: Enable USB keyboardSimon Glass
Enable the USB keyboard on sandbox, now that we have a suitable emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable console recording and silent consoleSimon Glass
Allow console recording so that tests can use it. Also allow the console output to be suppressed, to reduce test output 'noise'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-02sandbox: add ADC driverPrzemyslaw Marczak
This commit adds implementation of Sandbox ADC device emulation. The device provides: - single and multi-channel conversion - 4 channels with predefined conversion output data - 16-bit resolution Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-10-22sandbox: Introduce dummy remoteproc nodesNishanth Menon
Introduce dummy devices for sandbox remoteproc device and enable it by default Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-10-11Add support for LZ4 decompression algorithmJulius Werner
This patch adds support for LZ4-compressed FIT image contents. This algorithm has a slightly worse compression ration than LZO while being nearly twice as fast to decompress. When loading images from a fast storage medium this usually results in a boot time win. Sandbox-tested only since I don't have a U-Boot development system set up right now. The code was imported unchanged from coreboot where it's proven to work, though. I'm mostly interested in getting this recognized by mkImage for use in a downstream project. Signed-off-by: Julius Werner <jwerner@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31pinctrl: sandbox: add sandbox pinctrl driverMasahiro Yamada
This driver actually does nothing but test pinctrl uclass, and demonstrate how things work. To try this driver, uncomment /* #define DEBUG */ in the drivers/pinctrl/pinctrl-sandbox.c, and debug messages will be displayed. DRAM: 128 MiB sandbox pinmux: group = 1 (serial_a), function = 1 (serial) Using default environment In: cros-ec-keyb Out: lcd Err: lcd Net: Net Initialization Skipped eth0: eth@10002000, eth1: eth@80000000, eth5: eth@90000000 => i2c dev 0 Setting bus to 0 sandbox pinmux: group = 0 (i2c), function = 0 (i2c) sandbox pinconf: group = 0 (i2c), param = 3, arg = 1 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-31tpm: Enable 'tpmtest' command for Chrome OS boards with TPMsSimon Glass
This command provides a few useful tests so enable it for common boards. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard<christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31dm: tpm: sandbox: Convert TPM driver to driver modelSimon Glass
Convert the sandbox TPM driver to use driver model. Add it to the device tree so that it can be found on start-up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-06sandbox: Enable devres subsystemSimon Glass
This should be used for sandbox. We can convert at least one driver to use it, but in the meantime, enable the feature so that the code is build-tested. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-06dm: Make regmap and syscon optionalSimon Glass
Not all boards use garbage collection in their link step, so we should avoid adding options that rely on this for prevention of code bloat. Add separate Kconfig options for syscon and regmap uclasses. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: test: Add a test for the system controller uclassSimon Glass
Add a test to confirm that we can access system controllers and find their driver data. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: test: Add a test for the LED uclassSimon Glass
Add a test to confirm that we can adjust LEDs using the led_gpio driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: test: Add a test for the mmc uclassSimon Glass
Add a test to confirm that we can probe this device. Since there is no MMC stack support in sandbox at present, this is as far as the test goes. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-21dm: test: Add a test for the ram uclassSimon Glass
Add a test to confirm that we can probe this device and get information on the available RAM. Signed-off-by: Simon Glass <sjg@chromium.org>
