path: root/configs/sandbox64_defconfig
2020-07-05sandbox, test: add test for GPIO_HOG functionHeiko Schocher
currently gpio hog function is not tested with "ut dm gpio" so add some basic tests for gpio hog functionality. For this enable GPIO_HOG in sandbox_defconfig, add in DTS some gpio hog entries, and add testcase in "ut dm gpio" command. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-29sandbox: drop CONFIG_SYS_RELOC_GD_ENV_ADDRAKASHI Takahiro
As we discussed in [1], this option is not needed for sandbox build. [1] https://lists.denx.de/pipermail/u-boot/2020-February/400182.html Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-08treewide: mem: Move mtest related defines to KconfigAshok Reddy Soma
Move below defines which are used by mtest utility to Kconfig. CONFIG_SYS_MEMTEST_START CONFIG_SYS_MEMTEST_END Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fix kmcoge5ne board, re-run migration as well] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-16Merge tag 'efi-2020-07-rc1' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-efi Pull request for UEFI sub-system for efi-2020-07-rc1 This pull request * provides an implementation of UEFI secure booting * fixes a problem with the rsa_mod_exp driver which stops some boards from booting when CONFIG_RSA is enabled which is needed for UEFI secure booting * enables the EFI_RNG_PROTOCOL if DM_RNG is enabled * fixes some function comments
2020-04-16sandbox: enable CMD_BOOTEFI_HELLO and CMD_EFIDEBUGHeinrich Schuchardt
'bootefi hello' is used in one of the Python tests. efidebug can be used to verify the correct initialization of the UEFI sub-system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromum.org>
2020-04-16configs: sandbox: enable LOG_SYSLOGHeinrich Schuchardt
For testing purposes enable the syslog logging driver. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-04-16sandbox: add extra configurations for UEFI and related testsAKASHI Takahiro
Adding those extra configurations allows us to successfully run UEFI secure boot pytest on Travis CI. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2020-03-31Merge branch 'next' of git://git.denx.de/u-boot-usb into nextTom Rini
2020-03-12test: enable RSA library test on sandboxAKASHI Takahiro
We want to always run RSA library test on sandbox build in Travis CI. Just adding CONFIG_RSA_VERIFY_WITH_PKEY would be good enough for this purpose. Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2020-03-11drivers/rng: simplify KconfigHeinrich Schuchardt
For all sandbox systems with DM_RNG we enable RNG_SANDBOX. So we can simply set the default to yes. All rng drivers depend on DM_RNG. Use a single 'if' instead of individual dependencies. Now 'make menuconfig' shows the individual drivers neatly indented under the DM_RNG entry. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Sughosh Ganu <sughosh.ganu@linaro.org>
2020-02-28configs: Resync with savedefconfigTom Rini
2020-02-06video: enable VIDEO_ANSI and all VIDEO_BBP optionsAnatolij Gustschin
This partially reverts changes by commit 2cc393f32fd9 ("video: make BPP and ANSI configs optional") since it caused issues with other boards (missing LCD console output on pinebook, x86 platform or sandbox). Enable all disabled options again and opt out of not supported color depth in board defconfigs. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Vagrant Cascadian <vagrant@debian.org>
2020-01-22configs: Resync with savedefconfigTom Rini
2020-01-07configs: sandbox: Enable random number generator(rng) deviceSughosh Ganu
Enable support for random number generator on sandbox configs. This is aimed primarily at adding unit test support for rng uclass. Signed-off-by: Sughosh Ganu <sughosh.ganu@linaro.org> Reviewed-by: Patrice Chotard <patrice.chotard@st.com> Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-12-15sandbox: Add a test for IRQSimon Glass
Add a simple sandbox test for this uclass. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-15sandbox: Add PCI driver and test for p2sbSimon Glass
Add a sandbox driver and PCI-device emulator for p2sb. Also add a test which uses a simple 'adder' driver to test the p2sb functionality. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2019-12-06video: make BPP and ANSI configs optionalAnatolij Gustschin
Many boards do not use all selected framebuffer depth configurations, for such boards there is some unused code in video and console uclass routines. Make depth specific code optional to avoid dead code and slightly reduce binary size. Also make ANSI code optional for the same reason. When i.e. using only VIDEO_BPP16 the code size shrinks (below values when using gcc-7.3.0): $ ./tools/buildman/buildman -b video-wip -sS wandboard ... 01: Merge git://git.denx.de/u-boot-sh 02: video: add guards around 16bpp/32bbp code 03: video: make BPP and ANSI configs optional arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0 Signed-off-by: Anatolij Gustschin <agust@denx.de> Tested-by: Eugen Hristev <eugen.hristev@microchip.com> Tested-by: Patrice Chotard <patrice.chotard@st.com> Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
2019-12-04mtd: ensure MTD is compiled when CMD_MTDPARTS is selectedMiquel Raynal
MTD support must be enabled when using mtdparts. Indeed, functions like get_mtd_info(), get_mtd_device() and put_mtd_device() are in drivers/mtd/mtd_uboot.c and are built only with CONFIG_MTD. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-25sandbox: enable USB_KEYBOARD_FN_KEYSHeinrich Schuchardt
Enable the support of function keys on the USB keyboard. This is necessary to test the USB keyboard driver. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-15sandbox64: enable command aesPhilippe Reynes
This commit add the support of command aes. Then, it may be used on pytest. Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-07-29sandbox: remove CONFIG_DM_I2C_COMPAT from defconfigsBartosz Golaszewski
There are no more "real" users of CONFIG_DM_I2C_COMPAT and we'll soon remove it altogether. Stop building it in sandbox mode. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Acked-by: Heiko Schocher <hs@denx.de>
2019-07-13rtc: add Microcrystal RV-8803 driverMichael Walle
Signed-off-by: Michael Walle <michael@walle.cc>
2019-06-21configs: Resync with savedefconfigTom Rini
2019-06-14net: Convert CONFIG_IP_DEFRAG to KconfigMarek Vasut
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers and whitelist. This patch is a follow-up on a patch by Christian Gmeiner with the added config/header/whitelist updates. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Joe Hershberger <joe.hershberger@ni.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-04-11sandbox: Enable fdtdec testsThierry Reding
Enable fdtdec tests on sandbox configurations so that they can be run to validate the fdtdec implementation. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-13sandbox: Increase the pre-relocation memorySimon Glass
This is close to full now, so increase it to avoid problems with adding more devices. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-30Merge git://git.denx.de/u-boot-dmTom Rini
2018-09-29test: Add tests for board uclassMario Six
Add tests for the new board uclass. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-09-28video_osd: Add osd sandbox driver and testsMario Six
Add sandbox driver and tests for the new OSD uclass. Signed-off-by: Mario Six <mario.six@gdsys.cc> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-08-07configs: Resync with savedefconfigTom Rini
2018-07-19drivers: smem: sandboxRamon Fried
Add Sandbox driver for SMEM. mostly stub operations. Signed-off-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-05-25configs: add TPMv2.x support in SandboxMiquel Raynal
Enable the Sandbox TPMv2 driver in all possible configurations. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-28configs: Resync with savedefconfigTom Rini
2018-04-08treewide: Migrate CONFIG_DISPLAY_BOARDINFO_LATE to KconfigMario Six
Migrate the CONFIG_DISPLAY_BOARDINFO_LATE option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-18sandbox: Add 64-bit sandboxMario Six
To debug device tree issues involving 32- and 64-bit platforms, it is useful to have a generic 64-bit platform available. Add a version of the sandbox that uses 64-bit integers for its physical addresses as well as a modified device tree. Signed-off-by: Mario Six <mario.six@gdsys.cc> Added CONFIG_SYS_TEXT_BASE to configs/sandbox64_defconfig Signed-off-by: Simon Glass <sjg@chromium.org>
