The fdt_path_offset() function is slow since it must scan the tree.
This substantial overhead now applies to all boards.
The original code may not be ideal but it is fit for purpose and is only
needed on a few boards.
Reverting this reduces time to set up driver model by about 30ms.
Before revert:
Accumulated time:
47,170 dm_r
53,237 dm_spl
572,986 dm_f
Accumulated time:
44,598 dm_r
50,347 dm_spl
549,133 dm_f
This reverts commit 26f981f295d00351b6f0c69b5317b254b2361cc0.
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
CONFIG_SYS_BOOTM_LEN
As part of this, rework error handling in boot/bootm.c so that we pass
the buffer size to handle_decomp_error as CONFIG_SYS_BOOTM_LEN will not
be available to host tools but we do know the size that we passed to
malloc().
Cc: Soeren Moch <smoch@web.de>
Asking if the alias we found actually points at the device tree node
we passed in (in the guise of its offset from blob) can be done simply
by asking if the fdt_path_offset() of the alias' path is identical to
offset.
In fact, the current method suffers from the possibility of false
negatives: dtc does not necessarily emit a phandle property for a node
just because it is referenced in /aliases; it only emits a phandle
property for a node if it is referenced in <angle brackets>
somewhere. So if both the node we passed in and the alias node we're
considering don't have phandles, fdt_get_phandle() returns 0 for both.
Since the proper check is so simple, there's no reason to hide that
behind a config option (and if one really wanted that, it should be
called something else because there's no need to involve phandle in
the check).
Signed-off-by: Rasmus Villemoes <rasmus.villemoes@prevas.dk>
Acked-by: Aswath Govindraju <a-govindraju@ti.com>
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This commit enables SYSRESET in the defconfigs for the
Atmel/Microchip platforms.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
https://source.denx.de/u-boot/custodians/u-boot-at91 into next
First set of u-boot-at91 features for the 2022.07 cycle:
This feature set includes the new driver for the Atmel TCB timer,
alignment in DT for sama7g5 and sama7g5ek board, one Kconfig conversion
for external reset, and the usage of Galois tables from ROM for sama5d2
device.
In Linux this DT file is named at91-sama7g5ek.dts. Rename it accordingly.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com>
CONFIG_NET_RETRY_COUNT
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_ARP_TIMEOUT
CONFIG_PHANDLE_CHECK_SEQ will allow different sequence number for nodes
that have the same name, but they are different.
In sama7g5ek case, there are multiple 'i2c@600' nodes which are child
nodes of different parent 'flexcom' nodes.
These are different i2c busses even if the node is the same, and have to be
differentiated.
Without this config, the sequence number 0 is reused for two i2c busses, and
this is something that we have to avoid:
Looking for 'i2c' at 4704, name i2c@600
- serial0, /ahb/apb/serial@e1824200
- i2c0, /ahb/apb/flexcom@e181c000/i2c@600
Found seq 0
i2c_post_bind: i2c@600, seq=0
Looking for 'i2c' at 6236, name i2c@600
Found seq 0
After this patch:
- i2c1, /ahb/apb/flexcom@e2818000/i2c@600
Found seq 1
Before the patch:
=> i2c bus
Bus 0: i2c@600
Bus 0: i2c@600 (active 0)
52: eeprom@52, offset len 1, flags 0
53: eeprom@53, offset len 1, flags 0
After the patch:
=> i2c bus
Bus 0: i2c@600
Bus 1: i2c@600 (active 1)
Rewrite the CONFIG_BOOTCOMMAND only if it's not previously configured from
defconfig file.
This allows the user to select from defconfig/menuconfig the desired
boot command.
Adjust the current board defconfigs to reflect the default booting command
for the specific ENV configuration.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
Prepare v2021.07-rc5
# gpg: Signature made Mon 28 Jun 2021 03:39:36 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# configs/am64x_evm_r5_defconfig
https://source.denx.de/u-boot/custodians/u-boot-atmel into next
First set of u-boot-atmel features for the 2021.10 cycle:
This feature set converts the boards pm9261 and pm9263 Ethernet support
to DM; enables hash command for all SAM boards; fixes the NAND pmecc
bit-flips correction; adds Falcon boot for sama5d3_xplained board; and
other minor adjustments.
Add hash and hash verify commands. These would be useful for
verifying copied data.
Add drivers for flexcom, i2c and eeproms
Add new config for storing environment from sdmmc0.
Also clean-up sama7g5ek_emmc1 to point to the proper mmc device.
Enable CCF for SAMA7G5.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Enable support for KSZ9131.
Enable mii command as ethernet's PHY specific programming is
based on it.
Enable autoboot.
Use PIT64B driver. ATMEL_PIT is not available for SAMA7G5.
Enable CONFIG_CPU.
Enable PLL driver for SAMA7G5.
Set malloc pool to 68K for sama7g5ek.
Add initial support for sama7g5 evaluation kit board.
