CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_NAND_U_BOOT_LOCATIONS
CONFIG_SYS_NAND_U_BOOT_OFFS
CONFIG_SYS_NAND_ONFI_DETECTION
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
When CONFIG_ATMEL_NAND_HW_PMECC is set, CONFIG_PMECC_CAP defaults
to the value of 2. At the conversion to Kconfig for the PMECC config
values, some boards/defconfigs were wrongly configured.
Update CONFIG_PMECC_CAP to the PMECC_CAP value before the conversion.
Fixes: 49ad40298c ("ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to Kconfig")
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
SPL_GENERATE_ATMEL_PMECC_HEADER selects:
ATMEL_NAND_HWECC [=y] && ATMEL_NAND_HW_PMECC [=y].
With the removal of SPL_GENERATE_ATMEL_PMECC_HEADER,
ATMEL_NAND_HW_PMECC and ATMEL_NAND_HWECC were no longer
selected. Also, when the SPL_GENERATE_ATMEL_PMECC_HEADER was removed,
the configs were not updated using savedefconfig, thus the
'commit d168bcb6fe39 ("configs: Resync with savedefconfig")'
further removes the CONFIG_PMECC_CAP value.
Update defconfigs and add CONFIG_ATMEL_NAND_HW_PMECC,
which selects ATMEL_NAND_HWECC, in order to restore NAND PMECC
support. Restore CONFIG_PMECC_CAP value.
Fixes: 57f76c2a47 ("configs: at91: remove SPL_GENERATE_ATMEL_PMECC_HEADER from non-nand configs")
As highlighted by Stefan in the commit e074d0f79b2e ("arm: at91:
gardena-smart-gateway-at91sam: Enable CONFIG_SYS_NAND_USE_FLASH_BBT")
it's important to use BBT when Linux enables it. We use it for a long
time on all our boards.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Acked-by: Alexander Dahl <ada@thorsis.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-atmel
First set of u-boot-atmel features for 2020.10 cycle
Now that CONFIG_SPL_SEPARATE_BSS is selected for all the AT91 based
boards, cleanups the defconfigs by removing it.
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
SPL_GENERATE_ATMEL_PMECC_HEADER will generate a header for the SPL for NAND
information. The initial stage 1 bootloader will use this header in case the
NAND flash doesn't support commands to retrieve sector size, etc.
However this header is bad for different boot media, like MMC or SPI.
In case SD_BOOT or SPI_BOOT is used, remove the config for this.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so
obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both
SPL and U-Boot.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
This commit converts the following items to Kconfig:
CONFIG_ATMEL_NAND_HWECC
CONFIG_PMECC_CAP
CONFIG_PMECC_SECTOR_SIZE
CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER
[PMECC References]
https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure
https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap
[Mailing List Thread]
https://lists.denx.de/pipermail/u-boot/2018-December/350666.html
Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment")
[trini: Make the migration be size neutral and possibly not fix the
above in all cases]
Reported-by: Daniel Evans <photonthunder@gmail.com>
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_NAND_ATMEL
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
ATMEL_SPI is now fully converted to driver-model and
respective boards switch to DM_SPI as well,
so make default y for ARCH_AT91
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Wenyou Yang <wenyouya@gmail.com>
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
