path: root/configs/sama5d4ek_mmc_defconfig
2015-02-07ARM: atmel: sama5d4ek: enable SPL supportBo Shen
The sama5d4ek support boot up from NAND flash, SD/MMC card and also the SPI flash. Signed-off-by: Bo Shen <voice.shen@atmel.com>
2014-11-17ARM: atmel: add sama5d4ek board supportBo Shen
The code for this board supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display - Support ethernet - Support USB mass storage Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
