path: root/configs/sama5d4_xplained_nandflash_defconfig
2015-02-07ARM: atmel: sama5d4_xplained: enable spl supportBo Shen
Signed-off-by: Bo Shen <voice.shen@atmel.com>
2014-11-17ARM: atmel: add sama5d4 xplained ultra board supportBo Shen
The code for this board supports following features: - Boot media support: NAND flash/SD card/SPI flash - Support LCD display (optional, disabled by default) - Support ethernet - Support USB mass storage Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
