On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Convert the board to support the video driver model, add the device
tree node, and remove the unnecessary code.
Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option,
which is deprecated, use the CONFIG_XXXX_BOOT options to
indicate the boot media, and the SoC is selected by the board.
Add the code to set the ethernet mac address from eeprom by using
the common code from the common folder.
Use the Atmel PIT timer driver which supports the driver model
and device tree.
Also introduce CONFIG_USE_BOOTARGS option so we can control if
CONFIG_BOOTARGS defined at all.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
[trini: Resync r8a779[56]_ulcb, various ls10xx targets]
Fix the UART input clock for the early debug UART, it should be
100MHz, instead of 88MHz.
Migrate all remaining instances of CMD_NAND, CMD_NAND_TRIMFFS
CMD_NAND_LOCK_UNLOCK and CMD_NAND_TORTURE from the headers into the
defconfig files.
Tested-by: Adam Ford <aford173@gmail.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Enable the early debug UART to debug problems when an ICE or other
debug mechanism is not available.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
Update the configuration files to support the device tree and
driver model, so do SPL. The device clock and pins configuration
are handled by the clock and the pinctrl drivers respectively.
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Enable the fitImage support for the entire SAMA5Dx lineup of CPUs.
The fitImage is superior image format to uImage and it is useful
to have it available.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Wenyou Yang <wenyou.yang@atmel.com>
[rebase on current ToT]
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. "tristate" type was changed
to "bool" (I believe we don't support modules for u-boot yet, right?).
CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along
as well.
Definitions were added to defconfig files in a way that
"make savedefconfig" generates exactly the same file as used defconfig.
[trini: Add zynq_zc702 conversion]
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
The board select menu in arch/arm/Kconfig is still big.
To slim down it, this commit moves AT91 boards to
arch/arm/mach-at91/Kconfig.
Also, consolidate "config SYS_SOC" in each board Kconfig.
The Kconfig files under board/ directory were modified with the
following command:
find board -name Kconfig | xargs sed -i -e '
/config SYS_SOC/ {
N
/default "at91"/ {
N
d
Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
Signed-off-by: Bo Shen <voice.shen@atmel.com>
The code for this board supports following features:
- Boot media support: NAND flash/SD card/SPI flash
- Support LCD display (optional, disabled by default)
- Support ethernet
- Support USB mass storage
