path: root/configs/sama5d3xek_spiflash_defconfig
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-08configs: at91: sama5: updated mtdparts variable in bootargsEugen Hristev
We have a new demo layout of our sama5 boards for the NAND Flash memory. According to this new layout, adjust the mtdparts variable in bootargs to align with this, which is available at : http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d3XplainedMainPage#NAND_Flash_demo_Memory_map, Based on original work by Wenyou Yang Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2017-09-29board: sama5d3xek: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-14board: sama5d3xek: Enable early debug UARTWenyou Yang
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-04-14board: sama5d3xek: Update to support DM/DTWenyou Yang
Update the configuration files to support the device tree and driver model, so do SPL. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Add back CONFIG_PHY_MICREL to prevent a build error: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-24ARM: atmel: Enable FIT image support for SAMA5DxMarek Vasut
Enable the fitImage support for the entire SAMA5Dx lineup of CPUs. The fitImage is superior image format to uImage and it is useful to have it available. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [rebase on current ToT] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
