CONFIG_SYS_MONITOR_LEN
To do this, we set a default of 0 for everyone because there are a
number of cases where we define CONFIG_SYS_MONITOR_LEN but the only
impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN +
CONFIG_ENV_SIZE, so we must continue to allow all boards to set this
value. Update the SPL code to use 200 KB as the default raw U-Boot size
directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value.
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
Now that all the old code is gone, rename this option. Driver model
migration is now complete.
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This commit enables SYSRESET in the defconfigs for the
Atmel/Microchip platforms.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
Cc: Ramon Fried <rfried.dev@gmail.com>
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
CONFIG_SYS_NAND_ONFI_DETECTION
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
When CONFIG_ATMEL_NAND_HW_PMECC is set, CONFIG_PMECC_CAP defaults
to the value of 2. At the conversion to Kconfig for the PMECC config
values, some boards/defconfigs were wrongly configured.
Update CONFIG_PMECC_CAP to the PMECC_CAP value before the conversion.
Fixes: 49ad40298c ("ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to Kconfig")
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
SPL_GENERATE_ATMEL_PMECC_HEADER selects:
ATMEL_NAND_HWECC [=y] && ATMEL_NAND_HW_PMECC [=y].
With the removal of SPL_GENERATE_ATMEL_PMECC_HEADER,
ATMEL_NAND_HW_PMECC and ATMEL_NAND_HWECC were no longer
selected. Also, when the SPL_GENERATE_ATMEL_PMECC_HEADER was removed,
the configs were not updated using savedefconfig, thus the
'commit d168bcb6fe39 ("configs: Resync with savedefconfig")'
further removes the CONFIG_PMECC_CAP value.
Update defconfigs and add CONFIG_ATMEL_NAND_HW_PMECC,
which selects ATMEL_NAND_HWECC, in order to restore NAND PMECC
support. Restore CONFIG_PMECC_CAP value.
Fixes: 57f76c2a47 ("configs: at91: remove SPL_GENERATE_ATMEL_PMECC_HEADER from non-nand configs")
As highlighted by Stefan in the commit e074d0f79b2e ("arm: at91:
gardena-smart-gateway-at91sam: Enable CONFIG_SYS_NAND_USE_FLASH_BBT")
it's important to use BBT when Linux enables it. We use it for a long
time on all our boards.
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Acked-by: Alexander Dahl <ada@thorsis.com>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs,
headers and whitelist.
Please note that this symbol already was used in Kconfig
(imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was
not available in Kconfig. This changes now with this patch and all
boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what
I also need on my GARDENA AT91SAM based board.
Cc: Miquel Raynal <miquel.raynal@bootlin.com>
[trini: Rework such that the configs are unchanged to start with]
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
SPL_GENERATE_ATMEL_PMECC_HEADER will generate a header for the SPL for NAND
information. The initial stage 1 bootloader will use this header in case the
NAND flash doesn't support commands to retrieve sector size, etc.
However this header is bad for different boot media, like MMC or SPI.
In case SD_BOOT or SPI_BOOT is used, remove the config for this.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
This commit converts the following items to Kconfig:
CONFIG_ATMEL_NAND_HWECC
CONFIG_PMECC_CAP
CONFIG_PMECC_SECTOR_SIZE
CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER
[PMECC References]
https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure
https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap
[Mailing List Thread]
https://lists.denx.de/pipermail/u-boot/2018-December/350666.html
Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment")
[trini: Make the migration be size neutral and possibly not fix the
above in all cases]
Reported-by: Daniel Evans <photonthunder@gmail.com>
Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
CONFIG_NAND_ATMEL
