path: root/configs/sama5d36ek_cmp_spiflash_defconfig
2019-03-04configs: at91: remove SPL_GENERATE_ATMEL_PMECC_HEADER from non-nand configsEugen Hristev
SPL_GENERATE_ATMEL_PMECC_HEADER will generate a header for the SPL for NAND information. The initial stage 1 bootloader will use this header in case the NAND flash doesn't support commands to retrieve sector size, etc. However this header is bad for different boot media, like MMC or SPI. In case SD_BOOT or SPI_BOOT is used, remove the config for this. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2019-01-21ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to KconfigDerald D. Woods
This commit converts the following items to Kconfig: CONFIG_ATMEL_NAND_HWECC CONFIG_ATMEL_NAND_HW_PMECC CONFIG_PMECC_CAP CONFIG_PMECC_SECTOR_SIZE CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER [PMECC References] https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap [Mailing List Thread] https://lists.denx.de/pipermail/u-boot/2018-December/350666.html Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment") [trini: Make the migration be size neutral and possibly not fix the above in all cases] Reported-by: Daniel Evans <photonthunder@gmail.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-08configs: at91: sama5: updated mtdparts variable in bootargsEugen Hristev
We have a new demo layout of our sama5 boards for the NAND Flash memory. According to this new layout, adjust the mtdparts variable in bootargs to align with this, which is available at : http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d3XplainedMainPage#NAND_Flash_demo_Memory_map, Based on original work by Wenyou Yang Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-04-08Migrate CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to KconfigAlex Kiernan
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Petr Vorel <petr.vorel@gmail.com> Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2017-10-16configs: Resync with savedefconfigTom Rini
2017-09-29board: sama5d3xek: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-09configs: sama5d3xek: add default config for CMP boardWenyou Yang
The sama5d36ek CMP board is the variant of sama5d3xek board. It is equipped with the low-power DDR2 SDRAM, PMIC ACT8865, and some power rails. The board is mainly used to measure the power consumption. As all those changes are done in at91bootstrap, in U-Boot, only use another device tree file, no code needed to change. As there is additional power consumption when enbling the USB Host and USB device, for the power consumption measurement intention, disable the USB host and device. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
