path: root/configs/sama5d2_xplained_spiflash_defconfig
2017-05-09configs: sama5d2_xplained: update for SPLWenyou Yang
Enable config options to support the SPL, increase the malloc memory size for the SPL and board_init_f stage and increase the memory space for the SPL binary. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-05-09configs: sama5d2_xplained: enable CONFIG_DM_ETHWenyou Yang
Enable CONFIG_DM_ETH to make MACB to support driver model. Because the USB Ether doesn't support driver model so far, remove this feature. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-01-31mmc: atmel: rename CONFIG_ATMEL_SDHCI to CONFIG_MMC_SDHCI_ATMELMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_AT91". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: make MMC driver entries dependent on MMCMasahiro Yamada
Currently, CONFIG_MMC is not related to any other options by "depends on" or "select". One of big advantages of using Kconfig is automatic dependency tracking, but the current state is lacking it. As the first step, make the existing MMC driver entries depend on MMC. This commit was created by the following steps: [1] Run the following script: --------------------8<-------------------- rm -f tmp.txt for d in $(find . -path './configs/*_defconfig') do if grep -q -e 'CONFIG_MSM_SDHCI=y' $d || grep -q -e 'CONFIG_ATMEL_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_DWMMC=y' $d || grep -q -e 'CONFIG_SH_SDHI=y' $d || grep -q -e 'CONFIG_PIC32_SDHCI=y' $d || grep -q -e 'CONFIG_ZYNQ_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_SDHCI=y' $d || grep -q -e 'CONFIG_MMC_UNIPHIER=y' $d || grep -q -e 'CONFIG_SANDBOX_MMC=y' $d then echo CONFIG_MMC=y >> $d echo ${d#./configs/} >> tmp.txt fi done tools/moveconfig.py -y -s -d tmp.txt rm tmp.txt --------------------8<-------------------- [2] surround MMC driver entries with "if MMC" and "endif" Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-28board: sama5d2_xplained: Enable an early debug UARTWenyou Yang
Enable an early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-10-28board: sama5d2_xplained: Move config options to defconfigsWenyou Yang
Move the config options from the include/configs/sama5d2_xplained.h to configs/sama5d2_xplained_*_defconfig. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-05-24ARM: atmel: Enable FIT image support for SAMA5DxMarek Vasut
Enable the fitImage support for the entire SAMA5Dx lineup of CPUs. The fitImage is superior image format to uImage and it is useful to have it available. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [rebase on current ToT] Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-02-02board: atmel: sama5d2_xplained: add SPL supportWenyou Yang
The sama5d2 Xplained SPL supports the boot medias: spi flash and SD Card. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-11-30arm: atmel: Add SAMA5D2 Xplained boardWenyou Yang
The board supports following features: - Boot media support: SD card/e.MMC/SPI flash, - Support LCD display (optional, disabled by default), - Support ethernet, - Support USB mass storage. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> [fix checkpatch warnings] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
