path: root/configs/sama5d2_xplained_spiflash_defconfig
2019-07-10Merge https://gitlab.denx.de/u-boot/custodians/u-boot-ubiTom Rini
[trini: Migrate sama5d27_som1_ek_qspiflash/sama5d2_xplained_qspiflash for CONFIG_ENV_SECT_SIZE] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-07-09configs: sama5d2_xplained: enable qspi controller and flashesTudor Ambarus
We have a macronix spi-nor flash on sama5d2_xplained RevB and a sst spi-nor flash on RevC. Select the rest for testing purposes. Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-07-09at91, omap2plus: configs: migrate CONFIG_ENV_ to defconfigsMarkus Klotzbuecher
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be able to use CONFIG_ENV_UBI_* on these architectures. As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE, ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to KConfig. This migration was run using an extended moveconfig.py which evaluates expressions such as "(512 << 10)". See patch ("moveconfig: expand simple expressions"). All modified boards were built with SOURCE_DATE_EPOCH=0 before and after the change and successfully confirmed that the identical binary is generated (the only exception was igep00x0, which does not define CONFIG_ENV_IS_IN_UBI in the original board header. Once that is defined, the test passes too). hs: rebased patch to: 68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT" Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com> Cc: Heiko Schocher <hs@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Tom Rini <trini@konsulko.com>
2018-10-22configs: at91: sama5: enable CMD_IMIEugen Hristev
Enable iminfo command with CONFIG_CMD_IMI Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28configs: sama5d2_xplained: add fdt overlay supportEugen Hristev
Add commands for fdt overlay merging. This is required for the boot scripts that detect PDAs and apply specific overlays to the DTB passed on to kernel. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28configs: sama5d2_xplained: add onewire and eeprom driversEugen Hristev
SAMA5D2 SoC can have extra clip boards (PDAs) connected, which have an EEPROM memory for identification. A special GPIO can be used to read this memory over 1wire protocol. Enabling one wire and eeprom drivers for this memory. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-05-23configs: sama5d2_xplained: fix bootcmd/args for spi+emmc demoEugen Hristev
For sama5d2_xplained_spiflash_defconfig, we have the demo layout as presented on this link: http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d2XplainedMainPage#SPI_eMMC_Flash_demo_Memory_map on SPI Flash (4 Mbyte) we have Bootstrap (second level bootloader), U-boot + env and kernel+dtb we keep on eMMC on single partition in /boot directory, formatted with ext4. Thus, changing the boot command to reflect this demo for the spiflash config, and fixing up bootargs. Sama5d2_xplained does not have NAND flash, so the bootargs were completely wrong. Fixes: "5abc1a45": common: Move CONFIG_BOOTARGS to Kconfig Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-05-23configs: sama5d2_xplained: enable ext4 command supportEugen Hristev
To support loading the zImage + DTB from the rootfs ext4 partitions, enable the ext4 command support. Based on original work by Wenyou Yang Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-04-06spi: atmel: default y if DM_SPI && ARCH_AT91Jagan Teki
ATMEL_SPI is now fully converted to driver-model and respective boards switch to DM_SPI as well, so make default y for ARCH_AT91 Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Wenyou Yang <wenyouya@gmail.com>
2017-09-29board: sama5d2_xplained: Convert to CONFIG_DM_VIDEOWenyou Yang
Convert the board to support the video driver model, add the device tree node, and remove the unnecessary code. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-14configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignmentWenyou Yang
To remove the assignment of CONFIG_SYS_EXTRA_OPTIONS option, which is deprecated, use the CONFIG_XXXX_BOOT options to indicate the boot media, and the SoC is selected by the board. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-09-11board: sama5d2_xplained: Replace code to set mac addressWenyou Yang
Replace the code to set the ethernet mac address with the code from the common folder. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-26board: atmel: Use the new PIT timer driverWenyou.Yang@microchip.com
Use the Atmel PIT timer driver which supports the driver model and device tree. Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
2017-05-09configs: sama5d2_xplained: update for SPLWenyou Yang
Enable config options to support the SPL, increase the malloc memory size for the SPL and board_init_f stage and increase the memory space for the SPL binary. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-05-09configs: sama5d2_xplained: enable CONFIG_DM_ETHWenyou Yang
Enable CONFIG_DM_ETH to make MACB to support driver model. Because the USB Ether doesn't support driver model so far, remove this feature. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2017-01-31mmc: atmel: rename CONFIG_ATMEL_SDHCI to CONFIG_MMC_SDHCI_ATMELMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_AT91". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: make MMC driver entries dependent on MMCMasahiro Yamada
Currently, CONFIG_MMC is not related to any other options by "depends on" or "select". One of big advantages of using Kconfig is automatic dependency tracking, but the current state is lacking it. As the first step, make the existing MMC driver entries depend on MMC. This commit was created by the following steps: [1] Run the following script: --------------------8<-------------------- rm -f tmp.txt for d in $(find . -path './configs/*_defconfig') do if grep -q -e 'CONFIG_MSM_SDHCI=y' $d || grep -q -e 'CONFIG_ATMEL_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_DWMMC=y' $d || grep -q -e 'CONFIG_SH_SDHI=y' $d || grep -q -e 'CONFIG_PIC32_SDHCI=y' $d || grep -q -e 'CONFIG_ZYNQ_SDHCI=y' $d || grep -q -e 'CONFIG_ROCKCHIP_SDHCI=y' $d || grep -q -e 'CONFIG_MMC_UNIPHIER=y' $d || grep -q -e 'CONFIG_SANDBOX_MMC=y' $d then echo CONFIG_MMC=y >> $d echo ${d#./configs/} >> tmp.txt fi done tools/moveconfig.py -y -s -d tmp.txt rm tmp.txt --------------------8<-------------------- [2] surround MMC driver entries with "if MMC" and "endif" Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-10-28board: sama5d2_xplained: Enable an early debug UARTWenyou Yang
Enable an early debug UART to debug problems when an ICE or other debug mechanism is not available. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
2016-10-28board: sama5d2_xplained: Move config options to defconfigsWenyou Yang
Move the config options from the include/configs/sama5d2_xplained.h to configs/sama5d2_xplained_*_defconfig. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
