path: root/configs/sama5d2_ptc_spiflash_defconfig
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-05-24board: atmel: add SAMA5D2 PTC Engineering boardWenyou Yang
The board supports following features: - Boot media support: NAND Flash/SPI Flash - Support ethernet - Support USB mass storage Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
