path: root/configs/sama5d2_ptc_spiflash_defconfig
2016-05-24board: atmel: add SAMA5D2 PTC Engineering boardWenyou Yang
The board supports following features: - Boot media support: NAND Flash/SPI Flash - Support ethernet - Support USB mass storage Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
