path: root/configs/sama5d2_ptc_ek_nandflash_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2020-07-28configs: Resync with savedefconfigTom Rini
2020-06-04configs: Resync with savedefconfigTom Rini
2020-02-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-12defconfigs: Migrate CONFIG_SYS_REDUNDAND_ENVIRONMENTTom Rini
Move this symbol to Kconfig. As part of this we can drop a UBI-specific symbol that was a stop-gap for not having this particular symbol in Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-25mtd: nand: raw: Move CONFIG_SYS_NAND_USE_FLASH_BBT to KconfigStefan Roese
Convert CONFIG_SYS_NAND_USE_FLASH_BBT to Kconfig, update defconfigs, headers and whitelist. Please note that this symbol already was used in Kconfig (imply in CONFIG_NAND_ATMEL) which did not work, since this symbol was not available in Kconfig. This changes now with this patch and all boards with CONFIG_NAND_ATMEL will have BBT enabled. Which is what I also need on my GARDENA AT91SAM based board. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Eugen Hristev <eugen.hristev@microchip.com> Cc: Miquel Raynal <miquel.raynal@bootlin.com> Cc: Gregory CLEMENT <gregory.clement@bootlin.com> [trini: Rework such that the configs are unchanged to start with] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-05-23configs: sama5d2_ptc_ek: fix NAND PMECC_CAPTudor Ambarus
CONFIG_PMECC_CAP has a higher priority than its ONFI detected parameter and will overwrite it when defined. As per commit 49ad40298cc5, CONFIG_PMECC_CAP has a default value of 2 if not otherwise stated. This results in the overwriting of the ONFI ECC bits value. The following errors are seen when booting the kernel from the nand flash: Loading Environment from NAND... PMECC: Too many errors NAND read from offset 140000 failed -74 *** Warning - some problems detected reading environment; recovered successfully *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: eth0: ethernet@f8008000 Hit any key to stop autoboot: 0 NAND read: device 0 offset 0x180000, size 0x80000 PMECC: Too many errors NAND read from offset 180000 failed -74 0 bytes read: ERROR NAND read: device 0 offset 0x200000, size 0x600000 PMECC: Too many errors NAND read from offset 200000 failed -74 0 bytes read: ERROR Bad Linux ARM zImage magic! Fix it by setting the right value for ECC bits. Fixes: 49ad40298cc5 ("ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to Kconfig") Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
2019-01-21ARM: at91: Convert SPL_GENERATE_ATMEL_PMECC_HEADER to KconfigDerald D. Woods
This commit converts the following items to Kconfig: CONFIG_ATMEL_NAND_HWECC CONFIG_ATMEL_NAND_HW_PMECC CONFIG_PMECC_CAP CONFIG_PMECC_SECTOR_SIZE CONFIG_SPL_GENERATE_ATMEL_PMECC_HEADER [PMECC References] https://www.at91.com/linux4sam/bin/view/Linux4SAM/PmeccConfigure https://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91Bootstrap [Mailing List Thread] https://lists.denx.de/pipermail/u-boot/2018-December/350666.html Fixes: 5541543f ("configs: at91: Remove CONFIG_SYS_EXTRA_OPTIONS assignment") [trini: Make the migration be size neutral and possibly not fix the above in all cases] Reported-by: Daniel Evans <photonthunder@gmail.com> Cc: Eugen Hristev <eugen.hristev@microchip.com> Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-10-22configs: sama5d2_ptc_ek: add default bootargs for NAND defconfigEugen Hristev
Add the default kernel bootargs according to our NAND flash demo layout: http://www.at91.com/linux4sam/bin/view/Linux4SAM/Sama5d2PtcEKMainPage#NAND_Flash_demo_Memory_map Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-10-22configs: at91: sama5: enable CMD_IMIEugen Hristev
Enable iminfo command with CONFIG_CMD_IMI Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28configs: sama5d2_ptc_ek: add fdt overlay supportEugen Hristev
Add commands for fdt overlay merging. This is required for the boot scripts that detect PDAs and apply specific overlays to the DTB passed on to kernel. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-09-28configs: sama5d2_ptc_ek: add onewire and eeprom driversEugen Hristev
SAMA5D2 SoC can have extra clip boards (PDAs) connected, which have an EEPROM memory for identification. A special GPIO can be used to read this memory over 1wire protocol. Enabling one wire and eeprom drivers for this memory. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-07-21configs: Make NAND_BOOT and ONENAND_BOOT imply NANDAdam Ford
Some boards indicate support from booting NAND or ONENAND booting, but don't enable the CONFIG_NAND. This makes those boards imply NAND which will make enabling other flags that are dependent on CONFIG_NAND possible and easier to migrate. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-07-21Convert CONFIG_NAND_ATMEL to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND_ATMEL Signed-off-by: Adam Ford <aford173@gmail.com>
2018-05-08defconfig: at91-sama5d2_ptc_ek: remove unused SYS_EXTRA_OPTIONSLudovic Desroches
Remove SYS_USE_NANDFLASH, SYS_USE_MMC as they are deprecated and unused. The board configurations already use CONFIG_SD_BOOT and CONFIG_NAND_BOOT respectively. Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> [eugen.hristev@microchip.com: rework on latest u-boot] Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2017-11-29board: atmel: add sama5d2_ptc_ek boardLudovic Desroches
Add the SAMA5D2 PTC EK board and remove the SAMA5D2 PTC ENGI board which was a prototype. Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
