path: root/configs/sama5d2_ptc_ek_mmc_defconfig
2017-11-29board: atmel: add sama5d2_ptc_ek boardLudovic Desroches
Add the SAMA5D2 PTC EK board and remove the SAMA5D2 PTC ENGI board which was a prototype. Signed-off-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Wenyou Yang <wenyou.yang@microchip.com>
