CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
[trini: Migrate sama5d27_som1_ek_qspiflash/sama5d2_xplained_qspiflash
for CONFIG_ENV_SECT_SIZE]
We use a sst spi-nor flash memory on sama5d27_som1_ek. Select
the others for testing purposes.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
This was already set for 'sama5d27_som1_ek_mmc_defconfig' (first SD
card, full size). Without this option set, the MAC address is not read
from the I²C EEPROM at boot, and remains unset:
U-Boot 2019.01 (Jan 01 2019 - 00:00:00 +0000)
CPU: SAMA5D27 1G bits DDR2 SDRAM
Crystal frequency: 24 MHz
CPU clock : 492 MHz
Master clock : 164 MHz
DRAM: 128 MiB
MMC: sdio-host@a0000000: 0, sdio-host@b0000000: 1
Loading Environment from FAT... OK
In: serial
Out: serial
Err: serial
Net:
Error: ethernet@f8008000 address not set.
eth-1: ethernet@f8008000
Hit any key to stop autoboot: 0
Signed-off-by: Alexander Dahl <ada@thorsis.com>
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so
obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both
SPL and U-Boot.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
Enable onewire support and commands, fdt overlay for the mmc1 defconfig.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Enable iminfo command with CONFIG_CMD_IMI
This adds a defconfig for sama5d27_som1_ek board to get environment from
uSD. The defconfig is made from sama5d27_som1_ek_mmc_defconfig, with
'bootcmd' and 'bootargs' changed to kernel, device-tree and rootfs from
uSD. The environment is expected to be found in uSD's FAT partition.
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@microchip.com>
