CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This commit allows the ATMEL_PIT_TIMER driver to be unselected in SPL and be
selected in u-boot proper. The SPL can use a different timer.
By having a separate Kconfig for ATMEL_TCB in SPL, the size of the SPL
decreases by 0.3 KBytes.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
This commit enables SYSRESET in the defconfigs for the
Atmel/Microchip platforms.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
The most commonly used value today is 0x2000 and not 0x400. Rework the
Kconfig logic to use this more frequently used value as the default.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
Cc: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Alison Wang <alison.wang@nxp.com>
Cc: Anastasiia Lukianenko <anastasiia_lukianenko@epam.com>
Cc: Andes <uboot@andestech.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bharat Gooty <bharat.gooty@broadcom.com>
Cc: David Lechner <david@lechnology.com>
Cc: Dzmitry Sankouski <dsankouski@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Gerald Kerma <dreagle@doukki.net>
Cc: Gregory CLEMENT <gregory.clement@bootlin.com>
Cc: Holger Brunck <holger.brunck@hitachienergy.com>
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Cc: Jassi Brar <jaswinder.singh@linaro.org>
Cc: Kristian Amlie <kristian.amlie@northern.tech>
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Liviu Dudau <liviu.dudau@foss.arm.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Lukasz Majewski <lukma@denx.de>
Cc: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Cc: Matthias Brugger <mbrugger@suse.com>
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: Michael Walle <michael@walle.cc>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Oleksandr Andrushchenko <oleksandr_andrushchenko@epam.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Cc: Patrice Chotard <patrice.chotard@foss.st.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Priyanka Jain <priyanka.jain@nxp.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Rayagonda Kokatanur <rayagonda.kokatanur@broadcom.com>
Cc: Sergey Temerkhanov <s.temerkhanov@gmail.com>
Cc: Stefan Bosch <stefan_b@posteo.net>
Cc: Stephan Gerhold <stephan@gerhold.net>
Cc: Tetsuyuki Kobayashi <koba@kmckk.co.jp>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Thomas Fitzsimmons <fitzsim@fitzsim.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Tony Dinh <mibodhi@gmail.com>
Cc: Trevor Woerner <twoerner@gmail.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: liuhao <liuhao@phytium.com.cn>
Cc: lixinde <lixinde@phytium.com.cn>
Cc: shuyiqi <shuyiqi@phytium.com.cn>
Cc: weichangzheng <weichangzheng@phytium.com.cn>
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Masami Hiramatsu <masami.hiramatsu@linaro.org>
Reviewed-by: Tony Dinh <mibodhi@gmail.com>
Reviewed-by: Patrice Chotard <patrice.chotard@foss.st.com>
Reviewed-by: Kristian Amlie <kristian.amlie@northern.tech>
CONFIG_AT91SAM9260
CONFIG_AT91SAM9G20
CONFIG_AT91SAM9XE
CONFIG_AT91SAM9261
CONFIG_AT91SAM9263
CONFIG_AT91SAM9G45
CONFIG_AT91SAM9M10G45
CONFIG_AT91SAM9N12
CONFIG_AT91SAM9RL
CONFIG_AT91SAM9X5
CONFIG_SAM9X60
CONFIG_SAMA7G5
CONFIG_SAMA5D2
CONFIG_SAMA5D3
CONFIG_SAMA5D4
These options are already select'd as needed, so we're just cleaning up
files here.
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Rename these options so that CONFIG_IS_ENABLED can be used with them.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: Fixup some incorrect renames]
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
Giant board is a tiny SBC based on the Adafruit Feather form factor,
created by groboards it contains a SAMA5D2 processor (SAMA5D27),
128 MB of RAM and a microSD card for storage.
Signed-off-by: Greg Gallagher <greg@embeddedgreg.com>
