Update defconfigs for using common clock framework compatible
clocks.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
CONFIG_ATMEL_NAND_HW_PMECC
CONFIG_ATMEL_NAND_HWECC
CONFIG_NAND_ATMEL
CONFIG_PMECC_CAP
CONFIG_PMECC_SECTOR_SIZE
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
CONFIG_MTD must be reserved for the MTD core. Like any other
subsystem, prefix the symbol by DM when it comes to DM support.
[trini: Add Kconfig files]
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
enable driver model for i2c, eeprom for mac retrieval from eeprom i2c memory,
and microchip_flexcom driver.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Enable support for onewire memories and onewire commands.
Boot from QSPI nor flash.
The at91bootstrap, u-boot, u-boot env redundant, u-boot env,
device tree and kernel will reside in the QSPI nor flash.
The rootfs will reside in the NAND flash.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
