Update defconfigs for using common clock framework compatible
clocks.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
CONFIG_ATMEL_NAND_HW_PMECC
CONFIG_ATMEL_NAND_HWECC
CONFIG_NAND_ATMEL
CONFIG_PMECC_CAP
CONFIG_PMECC_SECTOR_SIZE
Like in Linux, just use CONFIG_MTD to compile the MTD stack.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
Add more clarity by changing the Kconfig entry name.
[trini: Re-run migration, update a few more cases]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
Move this symbol to Kconfig. As part of this we can drop a UBI-specific
symbol that was a stop-gap for not having this particular symbol in
Kconfig.
enable driver model for i2c, eeprom for mac retrieval from eeprom i2c memory,
and microchip_flexcom driver.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Enable support for onewire memories and onewire commands.
Boot from nand flash.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
