Enable Device model supported NAND driver and remove legacy Atmel NAND
driver.
Signed-off-by: Balamanikandan Gunasundar <balamanikandan.gunasundar@microchip.com>
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE
and this makes it imposible to use CONFIG_VAL().
Rename it to resolve this problem.
- Migrate more CONFIG options to Kconfig and remove some unused code
while we're at it.
Add the configurations required for enabling QSPI and the SF command
to allow changes to be made dynamically to serial flash devices from
the command line interface.
Signed-off-by: Sergiu Moga <sergiu.moga@microchip.com>
Reviewed-by: Tudor Ambarus <tudor.ambarus@microchip.com>
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SYS_CBSIZE
CONFIG_SYS_PBSIZE
This commit enables SYSRESET in the defconfigs for the
Atmel/Microchip platforms.
CONFIG_ATMEL_LEGACY
Cc: Eugen Hristev <eugen.hristev@microchip.com>
CONFIG_BOOTP_MAY_FAIL
CONFIG_BOOTP_VENDOREX
CONFIG_BOOTP_BOOTFILESIZE
CONFIG_BOOTP_NISDOMAIN
CONFIG_BOOTP_TIMEOFFSET
Cc: Ramon Fried <rfried.dev@gmail.com>
https://source.denx.de/u-boot/custodians/u-boot-at91 into next
First set of u-boot-at91 features for the 2022.04 cycle:
This feature set includes : support for the new QSPI hardware on
sama7g5, small fixes on sam9x60 and sama7g5, some additions of commands
and PIO controller on sam9x60/sam9x60ek.
CONFIG_USE_BOOTCOMMAND
CONFIG_BOOTCOMMAND
CONFIG_RAMBOOTCOMMAND
CONFIG_NFSBOOTCOMMAND
Add clock command for CLK sub-system and gpio command for query and control gpio
pins.
Signed-off-by: Mihai Sain <mihai.sain@microchip.com>
CONFIG_SYS_NAND_ONFI_DETECTION
Enable CONFIG_CPU for SAM9X60EK configs.
Reported-by: Eugen Hristev <eugen.hristev@microchip.com>
Fixes: a64862284f65 ("clk: at91: sam9x60: add support compatible with
CCF")
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Prepare v2021.07-rc5
# gpg: Signature made Mon 28 Jun 2021 03:39:36 PM EDT
# gpg: using RSA key 1A3C7F70E08FAB1707809BBF147C39FF9634B72C
# gpg: Good signature from "Thomas Rini <trini@konsulko.com>" [ultimate]
# Conflicts:
# configs/am64x_evm_r5_defconfig
https://source.denx.de/u-boot/custodians/u-boot-atmel into next
First set of u-boot-atmel features for the 2021.10 cycle:
This feature set converts the boards pm9261 and pm9263 Ethernet support
to DM; enables hash command for all SAM boards; fixes the NAND pmecc
bit-flips correction; adds Falcon boot for sama5d3_xplained board; and
other minor adjustments.
Add hash and hash verify commands. These would be useful for
verifying copied data.
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Enable NAND on mmc defconfig for greater flexibility and for consistency
reasons. All our other boards that have a NAND flash integrated, enable
NAND regardless of the type of the defconfig.
Signed-off-by: Tudor Ambarus <tudor.ambarus@microchip.com>
Update defconfigs for using common clock framework compatible
clocks.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
enable driver model for i2c, eeprom for mac retrieval from eeprom i2c memory,
and microchip_flexcom driver.
Enable support for onewire memories and onewire commands.
add sam9x60ek_mmc_defconfig and for now only supports booting from
sdcard.
Signed-off-by: Sandeep Sheriker Mallikarjun <sandeepsheriker.mallikarjun@microchip.com>
Signed-off-by: Nicolas Ferre <nicolas.ferre@microchip.com>
[nicolas.ferre@microchip.com: split patch, add Ethernet controller,
phy and tools]
[claudiu.beznea@microchip.com: add CONFIG_OF_LIBFDT_OVERLAY]
[tudor.ambarus@microchip.com: Fix number of DRAM banks:
One DDR2-SDRAM (W972GG6KB 2 Gbit = 16 Mbit x 16 x 8 banks]
