path: root/configs/s400_defconfig
2019-04-23board: amlogic: enable PHY_REALTEK for selected boardsNeil Armstrong
When using the generic PHY on boards using an RGMII Realtek PHY, gigabit speed is not always reliable. This patch enables the Realtek PHY driver for such boards. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
2019-04-10ARM: meson: display Amlogic SoC InformationJulien Masson
The Amlogic SoCs have a registers containing the die revision and packaging type to determine the SoC family and package marketing name like S905X for the GXL SoC Family. This code is taken from the Linux meson-gx-socinfo driver and adapted to U-Boot printing. Signed-off-by: Julien Masson <jmasson@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> [narmstrong: also updated new p200/p201 defconfigs]
2018-11-26board: amlogic: add support for S400 boardNeil Armstrong
The S400 board is the Amlogic AXG SoC reference board including : - Amlogic A113DX ARM Cortex-A53 quad-core SoC @ 1.2GHz - 1GB DDR4 SDRAM - 10/100 Ethernet - 2 x USB 2.0 Host - eMMC - Infrared receiver - SDIO WiFi Module - MIPI DSI Connector - Audio HAT Connector - PCI-E M.2 Connectors Signed-off-by: Jerome Brunet <jbrunet@baylibre.com> Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
