path: root/configs/s32v234evb_defconfig
2018-04-28serial: Migrate CONFIG_FSL_LINFLEXUART to KconfigTuomas Tynkkynen
2018-04-28ARM: s32v234evb: Set CONFIG_DM & CONFIG_DM_SERIAL in KconfigTuomas Tynkkynen
These symbols are declared in Kconfig, so it's wrong to set them in header files. Note that this is not size-neutral - some 'default y' options will now get turned on by Kconfig, such as CONFIG_CMD_DM=y and CONFIG_DM_STDIO=y. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2018-04-08treewide: Migrate CONFIG_SYS_ALT_MEMTEST to KconfigMario Six
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc> [trini: Re-run migration after also including CMD_MEMTEST] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-10-10configs: Re-sync CONFIG_CMD_IMLS with moveconfigTuomas Tynkkynen
The option is specified in Kconfig, but still a few config header files are overriding the choice by #undef'ing it. Re-sync the option with moveconfig to rid of the #undefs. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-24Move CONFIG_SYS_HUSH_PARSER to Kconfig for last 4 boardsMasahiro Yamada
I still see some defines of this config in board headers. Move them to defconfigs (+ renaming to CONFIG_HUSH_PARSER) to complete this migration. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-13armv8: s32v234: Introduce basic support for s32v234evbEddy Petrișor
Add initial support for NXP's S32V234 SoC and S32V234EVB board. The S32V230 family is designed to support computation-intensive applications for image processing. The S32V234, as part of the S32V230 family, is a high-performance automotive processor designed to support safe computation-intensive applications in the area of vision and sensor fusion. Code originally writen by: Original-signed-off-by: Stoica Cosmin-Stefan <cosminstefan.stoica@freescale.com> Original-signed-off-by: Mihaela Martinas <Mihaela.Martinas@freescale.com> Original-signed-off-by: Eddy Petrișor <eddy.petrisor@gmail.com> Signed-off-by: Eddy Petrișor <eddy.petrisor@nxp.com>
