path: root/configs/rpi_3_defconfig
2017-09-27usb: kbd: Set a default polling mechanism for USB keyboardBin Meng
The choice of "USB keyboard polling" cannot be optional as without one mechanism being set, it just doesn't work. Set the default one to CONFIG_SYS_USB_EVENT_POLL. Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08configs: Resync with savedefconfigTom Rini
2017-09-07Revert "dm: arm: rpi: Drop CONFIG_OF_EMBED"Paul Barker
This reverts commit 25877d4e4c45451c5398aec3de50e0d5befe0e9f. This is a workaround for Raspberry Pi boot failures seen when passing on the device tree provided by the Raspberry Pi firmware at boot. Without CONFIG_OF_EMBED, we just get stuck at "Starting kernel ..." when we try to boot Linux with this device tree. Signed-off-by: Paul Barker <pbarker@toganlabs.com> Cc: Simon Glass <sjg@chromium.org> Tested-by: Jonathan Gray <jsg@jsg.id.au> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-26rpi: Enable USB keyboard supportSimon Glass
This is currently disabled, so USB keyboards are not detected in U-Boot. Enable this option to fix that. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Jonathan Gray <jsg@jsg.id.au> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Paul Barker <pbarker@toganlabs.com>
2017-07-31env: Migrate CONFIG_ENV_IS_IN_FAT options to KconfigTom Rini
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that they can be modified via Kconfig. Migrate all existing users to the new values. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-07-06Raspberry Pi: add device tree overlay supportPeter Robinson
Raspberry Pi has numerous HAT and other HW expansion options such as screens and cameras some of which need overlays from the beginning so it makes sense to enable evice tree overlays. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2017-05-09dm: video: arm: rpi: Convert to use driver model for videoSimon Glass
Adjust the video driver to work with driver model and move over existing baords. There is no need to keep the old code. We can also drop setting of CONFIG_FB_ADDR since driver model doesn't have this problem. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2017-05-09dm: arm: rpi: Drop CONFIG_OF_EMBEDSimon Glass
We should not use an embedded device tree on a production board. There does not seem to be any reason for it in commit 7670909. So drop this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09dm: mmc: rpi: Convert Raspberry Pi to driver model for MMCSimon Glass
Convert the bcm2835 SDHCI driver over to support CONFIG_DM_MMC and move all boards over. There is no need to keep the old code since there are no other users. Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09dm: arm: rpi: Use driver model for EthernetSimon Glass
Enable CONFIG_DM_ETH so that driver model is used for the USB Ethernet device. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-09dm: arm: rpi: Move to driver model for USBSimon Glass
Start using driver model for USB on the Raspberry Pi. The dwc2 supports this now so this is just a config change. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-03Enable DISTRO_DEFAULT on platforms that missed it beforeTom Rini
A number of platforms had been using the distro default feature before it was moved to Kconfig but did not enable the new Kconfig option when it was enabled. This caused a regression in terms of features and this introduces breakage when more things move to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-28ARM: bcm283x: use OF_CONTROL for bcm283xFabian Vogt
This patch removes use of U_BOOT_DEVICE in board/raspberrypi/rpi/rpi.c, enables OF_CONTROL in the config and adjusts the rpi_*defconfig configs. Signed-off-by: Fabian Vogt <fvogt@suse.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-06serial: bcm283x_mu: Detect disabled serial deviceAlexander Graf
On the raspberry pi, you can disable the serial port to gain dynamic frequency scaling which can get handy at times. However, in such a configuration the serial controller gets its rx queue filled up with zero bytes which then happily get transmitted on to whoever calls getc() today. This patch adds detection logic for that case by checking whether the RX pin is mapped to GPIO15 and disables the mini uart if it is not mapped properly. That way we can leave the driver enabled in the tree and can determine during runtime whether serial is usable or not, having a single binary that allows for uart and non-uart operation. Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-04-11ARM: add Raspberry Pi 3 64-bit configStephen Warren
On all Pis so far, the VC FW provides a short stub to set up the ARM CPU before entering the kernel (a/k/a U-Boot for us). This feature is not currently supported by the VC FW when booting in 64-bit mode. However, this feature will likely appear in the near future, and this U-Boot port assumes that such a feature is in place. Without that feature, or a temporary workaround described below, U-Boot will not boot. Once the VC FW does provide the ARM stub, u-boot.bin built for rpi_3 can be used drectly as kernel7.img, in the same way as any other RPi port. The following config.txt is required: # Fix mini UART input frequency, and setup/enable up the UART. # Without this option, U-Boot will not boot, even if you don't care # about the serial console. This option will always be required for # all RPi3 use-cases, unless the PL011 UART is used, which is not # yet supported by rpi_3* builds of U-Boot. enable_uart=1 # Boot in AArch64 (64-bit) mode. # It is possible that a future VC FW will remove the need for this # option, instead auto-setting 32-/64-bit mode based on the "kernel" # filename present on the SD card. arm_control=0x200 Prior to the VC FW providing the ARM boot stub, you can use the following steps to build an equivalent stub into the U-Boot binary: git clone https://github.com/swarren/rpi-3-aarch64-demo.git \ ../rpi-3-aarch64-demo (cd ../rpi-3-aarch64-demo && ./build.sh) Build U-Boot for rpi_3 in the usual way cat ../rpi-3-aarch64-demo/armstub64.bin u-boot.bin > u-boot.bin.stubbed Use u-boot.bin.stubbed as kernel7.img on the Pi SD card. In this case, the following additional entries are required in config.txt: # Tell the FW to load the kernel image at address 0, the reset vector. kernel_old=1 Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Reviewed-by: Tom Rini <trini@konsulko.com>
