CONFIG_LCD_DT_SIMPLEFB
This patch also renames this config to CONFIG_FDT_SIMPLEFB as the code in
common/lcd_simplefb.c support CONFIG_LCD and CONFIG_VIDEO.
Signed-off-by: Patrick Delaunay <patrick.delaunay@foss.st.com>
Reviewed-by: Matthias Brugger <mbrugger@suse.com>
Prepare v2021.10-rc5
Enable this driver to allow U-Boot to get SMBIOS table information from
a device tree node.
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
Acked-by: Fabian Vogt <fvogt@suse.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
TFTP transfer size can be used to re-size the TFTP progress bar on
single line based on the server reported file size. The support for
this has been around from 2019, but it was never converted to proper
Kconfig.
While adding this new Kconfig, enable it by default for OMAP2+ and K3
devices also.
Signed-off-by: Tero Kristo <kristo@kernel.org>
This commit moves CONFIG_PREBOOT="usb start" to common/KConfig
for all boards also declaring USB_KEYBOARD.
Besides simplifying defconfig files, this also enables support for
board-specific CONFIG_PREBOOT for sunxi boards:
commit 37304aaf60bf ("Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to
Kconfig") intended to support CONFIG_PREBOOT, but
include/configs/sunxi-common.h hardcodes preboot as part of internally
defined CONSOLE_STDIN_SETTINGS, silently ignoring any board-specific
CONFIG_PREBOOT.
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Reviewed-by: Neil Armstrong <narmstrong@baylibre.com>
Series-Cc: Jagan Teki <jagan@amarulasolutions.com>
Series-Cc: Lukasz Majewski <lukma@denx.de>
Series-Cc: Andre Przywara <andre.przywara@arm.com>
This partially reverts changes by commit 2cc393f32fd9
("video: make BPP and ANSI configs optional") since it
caused issues with other boards (missing LCD console
output on pinebook, x86 platform or sandbox). Enable
all disabled options again and opt out of not supported
color depth in board defconfigs.
Reported-by: Vagrant Cascadian <vagrant@debian.org>
Many boards do not use all selected framebuffer depth
configurations, for such boards there is some unused
code in video and console uclass routines. Make depth
specific code optional to avoid dead code and slightly
reduce binary size. Also make ANSI code optional for
the same reason. When i.e. using only VIDEO_BPP16 the
code size shrinks (below values when using gcc-7.3.0):
$ ./tools/buildman/buildman -b video-wip -sS wandboard
01: Merge git://git.denx.de/u-boot-sh
02: video: add guards around 16bpp/32bbp code
03: video: make BPP and ANSI configs optional
arm: (for 1/1 boards) all -776.0 bss -8.0 text -768.0
Tested-by: Eugen Hristev <eugen.hristev@microchip.com>
Tested-by: Patrice Chotard <patrice.chotard@st.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_ARCH_CPU_INIT
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Tested-by: Felix Brack <fb@ltec.ch>
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The most generic way of having a stable boot behavior is to rely on
UUID instead of device names for root partition, so the order of
probing does not cause issues with booting.
This enables the `CMD_FS_UUID` for following defconfig files:
- rpi_0_w_defconfig
- rpi_2_defconfig
- rpi_3_32b_defconfig
- rpi_3_defconfig
- rpi_defconfig
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br>
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Convert CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to Kconfig
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Petr Vorel <petr.vorel@gmail.com>
Reviewed-by: Petr Vorel <petr.vorel at gmail.com>
The new Raspberry Pi B 3+ has a lan78xx device attached to it. Let's add
driver support in U-Boot for it.
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
The bcm283x family of SoCs have a GPIO controller that also acts as
pinctrl controller.
This patch introduces a new pinctrl driver that can actually properly mux
devices into their device tree defined pin states and is now the primary
owner of the gpio device. The previous GPIO driver gets moved into a
subdevice of the pinctrl driver, bound to the same OF node.
That way whenever a device asks for pinctrl support, it gets it
automatically from the pinctrl driver and GPIO support is still available
in the normal command line phase.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The choice of "USB keyboard polling" cannot be optional as without
one mechanism being set, it just doesn't work. Set the default one
to CONFIG_SYS_USB_EVENT_POLL.
Fixes: ecad7051 ("configs: Migrate all of the existing USB symbols, except fastboot")
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig.
Update defconfigs.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on
USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and
LAN78XX options under new menu. Finally update the defconfigs that need
CONFIG_USB_HOST_ETHER.
This reverts commit 25877d4e4c45451c5398aec3de50e0d5befe0e9f.
This is a workaround for Raspberry Pi boot failures seen when passing on
the device tree provided by the Raspberry Pi firmware at boot. Without
CONFIG_OF_EMBED, we just get stuck at "Starting kernel ..." when we try
to boot Linux with this device tree.
Signed-off-by: Paul Barker <pbarker@toganlabs.com>
Tested-by: Jonathan Gray <jsg@jsg.id.au>
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
This is currently disabled, so USB keyboards are not detected in U-Boot.
Enable this option to fix that.
Tested-by: Paul Barker <pbarker@toganlabs.com>
We rename the various FAT_ENV_xxx options to CONFIG_ENV_FAT_xxx so that
they can be modified via Kconfig. Migrate all existing users to the new
values.
This change migrates the USB_DWC2 configuration item to Kconfig
and runs moveconfig to adjust header files and defconfig.
Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com>
Split off into a separate patch:
Ran moveconfig to migrate other boards:
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Raspberry Pi has numerous HAT and other HW expansion options such as screens and
cameras some of which need overlays from the beginning so it makes sense to
enable evice tree overlays.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Adjust the video driver to work with driver model and move over existing
baords. There is no need to keep the old code.
We can also drop setting of CONFIG_FB_ADDR since driver model doesn't have
this problem.
Acked-by: Anatolij Gustschin <agust@denx.de>
We should not use an embedded device tree on a production board. There
does not seem to be any reason for it in commit 7670909. So drop this.
