path: root/configs/rock_defconfig
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-13serial: ns16550: Link in the DM driver when when using platdataAlexandru Gagniuc
Do not condition the compilation of the U_BOOT_DRIVER by !OF_PLATDATA. This is inconsistent with the majority of other drivers. This also blocks OF_PLATDATA boards with an 16550-compatible serial from using serial in SPL. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Reviewed-by: Simon Glass <sjg@chromium.org> Added tweak for rock to avoid a TPL build failure: Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-04rockchip: rk3188: Add Radxa Rock boardHeiko Stübner
The Rock is a RK3188 based single board computer by Radxa. Currently it still relies on the proprietary DDR init and cannot use the generic SPL, but at least is able to boot a linux kernel and system up to a regular login prompt. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fix sort order in defconfig, enable CONFIG_SPL_TINY_MEMSET: Signed-off-by: Simon Glass <sjg@chromium.org>
