path: root/configs/rock960-rk3399_defconfig
2019-05-08arm: rockchip: rk3399: Move common configs in KconfigJagan Teki
Few SPL and U-Boot proper configs are common to all rk3399 target defconfigs, move them and select it from platform kconfig. Moved configs: - SPL_ATF - SPL_ATF_NO_PLATFORM_PARAM if SPL_ATF - SPL_LOAD_FIT - SPL_CLK if SPL - SPL_PINCTRL if SPL - SPL_RAM if SPL - SPL_REGMAP if SPL - SPL_SYSCON if SPL - CLK - FIT - PINCTRL - RAM - REGMAP - SYSCON - DM_PMIC - DM_REGULATOR_FIXED Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-08Kconfig: Add default SPL_FIT_GENERATOR for rockchipJagan Teki
Add default SPL_FIT_GENERATOR py script for rockchip platforms if specific target enabled SPL_LOAD_FIT. So, this would help get rid of explicitly mentioning the default SPL FIT generator in defconfigs. however some targets, like puma_rk3399 still require their own FIT generator so in those cases the default will override with defconfig defined generator. Reviewed-by: Paul Kocialkowski <paul.kocialkowski@bootlin.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-02-07configs: Resync with savedefconfigTom Rini
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-06rockchip: rk3399: Add Rock960 CE board supportManivannan Sadhasivam
Add board support for Rock960 CE board from Vamrs. This board utilizes common Rock960 family support. Following peripherals are tested and known to work: * USB 2.0 * MMC This commit also adds DDR configuration for LPDDR3-2GiB-1600MHz which is being used on the board. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
