path: root/configs/rock64-rk3328_defconfig
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-22rockchip: rock64-rk3328_defconfig: Add SPI Flash supportJohannes Krottmayer
Add U-Boot SPI Flash support for the PINE64 Rock64 board Signed-off-by: Johannes Krottmayer <krjdev@gmail.com> Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-05-26configs: Resync with savedefconfigTom Rini
2020-05-22rockchip: rk3328: rock64 - fix gen3 SPL hangKurt Miller
Use the same approach as ROC-RK3328-CC which enables SPL GPIO, pinctl and regulator support. This allows the gen3 board to boot through SPL and does not break gen2 in the process. Signed-off-by: Kurt Miller <kurt@intricatesoftware.com> Acked-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-05-01rockchip: rk3328: Disable generic PHY supportChen-Yu Tsai
The USB PHYs on the RK3328 aren't supported, nor are any other generic PHYs. Because upstream Linux device trees already include the USB PHYs and references in the USB hosts, this would result in various calls to the generic PHY API to fail. Instead, just disable generic PHY support for now. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-06rockchip: rk3328: rock64: enable CONFIG_MISC_INIT_RBen Wolsieffer
This enables reading of the cpuid and a static MAC address. Signed-off-by: Ben Wolsieffer <benwolsieffer@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23Merge tag 'u-boot-rockchip-20191124' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Clean vid/pid in Kconfig and add fastboot for rk3399 - add 'u-boot, spl-fifo-mode' for mmc - Use FIT generator for rk3229 optee and rk3368 ATF - fan53555: add support for Silergy SYR82X and SYR83X
2019-11-23fastboot: rockchip: Select FASTBOOT_FLASH[_MMC_DEV]Jagan Teki
Select CONFIG_FASTBOOT_FLASH, CONFIG_FASTBOOT_FLASH_MMC_DEV for rockchip SoC plaforms in fastboot Kconfig file instead of defined it in board defconfig. This eventually drop the explicit configs defined in supporting board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23gadget: rockchip: USB_GADGET_PRODUCT_NUMJagan Teki
Rockchip support differnet or common gadget product number between Rockchip SoCs like, 0x310a - rk3036 0x320a - rk3229, rk3288 0x330a - rk3328 So, select them on Kconfig based on platform specific config defined.     This eventually drop the explicit configs defined in supporting board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23gadget: Select USB_GADGET_VENDOR_NUM for rockchipJagan Teki
Gadget vendor number, 0x2207 is common across all platfroms supported in Rockchip SoC. So, select the same number globally, if ARCH_ROCKCHIP. This eventually drop the explicit configs defined in supported board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-23gadget: Select USB_GADGET_MANUFACTURER for rockchipJagan Teki
Select the gadget manufacturer as 'Rockchip' for all rockchip platform SoC's. This eventually drop the explicit defined added on supported board defconfig files. Tested-by: Levin Du <djw@t-chip.com.cn> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-17ram: rk3328: use common sdram driverYouMin Chen
RK3328 has a similar controller and phy with PX30, so we can use the common driver for it and remove the duplicate codes. Signed-off-by: YouMin Chen <cym@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-11configs: Resync with savedefconfigTom Rini
2019-11-11Merge tag 'u-boot-rockchip-20191110' of ↵Tom Rini
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip - Add support for rockchip pmic rk805,rk809, rk816, rk817 - Add rk3399 board Leez support - Fix bug in rk3328 ram driver - Adapt SPL to support ATF bl31 with entry at 0x40000 - Fix the u8 type comparision with '-1'. - Fix checkpatch warning for multi blank line and review signature.
2019-11-10rockchip: rk3328: defconfig: no need to reserve IRAM for SPLKever Yang
We use to reserve IRAM to avoid the SPL text overlap with ATF M0 code, and when we introduce the TPL, the SPL space is in DRAM, we reserve space to avoid SPL text overlap with ATF bl31. Now we decide to move ATF entry point to 0x40000 instead of 0x1000, so that the SPL can have 0x4000 as code size and no need to reserve space or relocate before loading ATF. The mainline ATF has update since: 0aad563c rockchip: Update BL31_BASE to 0x40000 Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-10-24usb: dwc3: Kconfig: get rid of obsolete mode selectionJean-Jacques Hiblot
The mode selection for the DWC3 is kind of obsolete. The driver does not have to be host only or gadget only. This choice is confusing. All the remaining callers of dwc3_uboot_init() explicitly set dr_mode before calling the function, so none rely on a default behavior. Remove the choice menu and keep only the USB_DWC3_GADGET option. Enable it by default if USB_GADGET and USB_DWC3 are enabled. It must be disabled for the evb-rk3328 as it uses DWC2 for the gadget and DWC3 for the host. Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-08-23rockchip: rk3328: defconfig: remove SPL raw image supportKever Yang
RK3328 SPL only support FIT image for ATF bl31. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-08-14configs: Resync with savedefconfigTom Rini
2019-08-05configs: rk3328: enable TPL for rock64-rk3328_defconfigMatwey V. Kornilov
Until now, binary TPL by Rockchip has been required for booting procedure. Starting from this commit we may use only u-boot to boot the device. Note, that using binary TPL instead of U-boot TPL is still working. Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-20rockchip: rk3328: default enable SPL LIBCOMMON and LIBGENERICKever Yang
We needs SPL LIBCOMMON and LIBGENERIC for all boards, so we can enable them by default and no need to define in each board. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-20rockchip: rk3328: use defaule value for SYS_MALLOC_F_LENKever Yang
There is no difference in rk3328 board use for SYS_MALLOC_F_LEN, so we can use default value. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26rockchip: rk3328: add rock64-rk3328_defconfigMatwey V. Kornilov
The ROCK64 is a credit card size SBC based on Rockchip RK3328 Quad-Core ARM Cortex A53. This series allow building u-boot SPL and u-boot.itb for Rock64 board. The proprietary TPL is stil required for deploy: ./tools/mkimage -n rk3328 -T rksd \ -d ./rkbin/bin/rk33/rk3328_ddr_333MHz_v1.16.bin idbloader.img cat ./spl/u-boot-spl.bin >> idbloader.img dd if=idbloader.img of=/dev/sdcard seek=64 conv=notrunc dd if=u-boot.itb of=/dev/sdcard seek=16384 conv=notrunc Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
