path: root/configs/rock2_defconfig
2017-01-11rockchip: Enable ETH address randomization for the rock2Romain Perier
This commit enables ethernet MAC address randomization on the rock2. It removes the error at startup 'ethernet@ff290000 address not set'. Signed-off-by: Romain Perier <romain.perier@collabora.com>
2017-01-11rockchip: Enable networking support on rock2 and fireflySjoerd Simons
Enable the various configuration option required to get the ethernet interface up and running on Radxa Rock2 and Firefly. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Signed-off-by: Romain Perier <romain.perier@collabora.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-11mmc: rename CONFIG_ROCKCHIP_DWMMC to CONFIG_MMC_DW_ROCKCHIPMasahiro Yamada
I am trying to make all DesignWare-based driver options prefixed with CONFIG_MMC_DW_. This commit was generated as follows: find . -name .git -prune -o -type f -print | \ xargs sed -i -e 's/ROCKCHIP_DWMMC/MMC_DW_ROCKCHIP/g' Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-01Enable ROCKCHIP_SPL_BACK_TO_BROM for rock2 boardSandy Patterson
Rock2 has been tested with back to brom feature. The tricky part is that with this feature the default environment is inside u-boot, and it's defined for every rk3288 board independetly. So I just changed it for rock2 here if ROCKCHIP_SPL_BACK_TO_BROM. Solve by moving environment after u-boot before 1M boundary Signed-off-by: Sandy Patterson <apatterson@sightlogix.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: rk3288: pinctrl: fix config symbol namingHeiko Stübner
The rk3288 pinctrl is very specific to this soc, so should not hog the generic rockchip naming. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-22defconfig: Reorder boards' defconfig filesBin Meng
Some boards' defconfig files are out of order. Clean this up. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-02-06rockchip: Drop old CONFIG_VIDEO_ROTATION optionSimon Glass
The option was renamed to CONFIG_CONSOLE_ROTATION and Rockchip boards were not updated. However this option is is not needed by default for Rockchip since we don't need a rotated console for current boards. So just remove the old option. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-26video: add CONFIG_I2C_EDID and disable CONFIG_DISPLAY by defaultAnatolij Gustschin
Enabling CONFIG_DISPLAY breaks building for some architectures (microblaze-generic), so we disable CONFIG_DISPLAY in Kconfig by default and enable this option in defconfigs. CONFIG_DISPLAY depends on CONFIG_I2C_EDID, so add and enable it in defconfigs, too. Signed-off-by: Anatolij Gustschin <agust@denx.de> Reported-by: Bin Meng <bmeng.cn@gmail.com> Cc: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2016-01-21rockchip: Add support for Raxda Rock 2Simon Glass
This board includes an RK3288 SoC on a SOM. It can be mounted on a base-board which provides a wide range of peripherals. So far this is verified to boot to a prompt from a microSD card. The serial console works as well as HDMI. Thanks to Tom Cubie for sending me a board. Signed-off-by: Simon Glass <sjg@chromium.org>
