CONFIG_SPL_BSS_START_ADDR
CONFIG_SPL_STACK
- Make all users of CUSTOM_SYS_INIT_SP_ADDR reference SYS_INIT_SP_ADDR
- Introduce HAS_CUSTOM_SYS_INIT_SP_ADDR to allow for setting the stack
pointer directly, otherwise we use the common calculation.
- On some platforms that were using the standard calculation but did not
set CONFIG_SYS_INIT_RAM_SIZE / CONFIG_SYS_INIT_RAM_ADDR, set them.
- On a small number of platforms that were not subtracting
GENERATED_GBL_DATA_SIZE do so now via the standard calculation.
- CONFIG_SYS_INIT_SP_OFFSET is now widely unused, so remove it from most
board config header files.
CONFIG_SPL_BSS_MAX_SIZE
CONFIG_SPL_MAX_FOOTPRINT
Note that the da850evm platforms were violating the "only use one" rule
here, and so now hard-code their BSS limit.
CONFIG_SPL_PAD_TO
CONFIG_SPL_MAX_SIZE
CONFIG_TPL_PAD_TO
CONFIG_TPL_MAX_SIZE
Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the
existing places.
Set CONFIG_COUNTER_FREQUENCY according to COUNTER_FREQUENCY in
config header file.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
[trini: Re-run migration]
Apple SoCs have an integrated NVMe controller that isn't connected
over a PCIe bus. In preparation for adding support for this NVMe
controller, split out the PCI support into its own file. This file
is selected through a new CONFIG_NVME_PCI Kconfig option, so do
a wholesale replacement of CONFIG_NVME with CONFIG_NVME_PCI.
Signed-off-by: Mark Kettenis <kettenis@openbsd.org>
Tested on: Macbook Air M1
The 64 bit rk33xx chips don't have the ROCKCHIP_USB2_PHY IP so
drop the configs as they were likely copied over from other
boards during enablement.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
Reviewed-by: Rick Chen <rick@andestech.com>
SPI flash on this board is located on bus 1, default to using bus 1 for
SPI flash on both rk3399-roc-pc and -mezzanine, and stop aliasing it to
bus 0.
Signed-off-by: Hugh Cole-Baker <sigmaris@gmail.com>
Suggested-by: Simon Glass <sjg@chromium.org>
Fixes: c4cea2bb ("rockchip: Enable building a SPI ROM image on bob")
Reviewed-by: Kever Yang<kever.yang@rock-chips.com>
ROC-RK3399-PC has specific set of configurations for
on-board led setup.
Due to easiness for user to know the state of the board
roc-rk339-pc board code will setup the low power led
on/off, and waiting for user to press power key and then
glow full power led.
All this needs to happen only during power-on-reset not
for soft reset or WDT.
Also, it is not a proper usage to ask the user to press
the Power key if the board connected remotely, so add
the environment variable 'pwr_key' to check as well.
So, user need to press Power key only
- during POR
- pwr_key=y
Tested-by: Suniel Mahesh <sunil@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
roc-rk3399-pc has some specific requirements to support LEDS,
environment. board detection and etc prior to U-Boot proper.
So as of now SPL would be a better stage for these custom board
requirements to support unlike TPL. Adding few of these custom
requirements like LEDS in TPL would require extra code pulling
and also the size of TPL can grow.
So, this patch moves the leds code from TPL into SPL Board init
led_setup code.
(split tpl.c change as separate patch)
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Disable ram rockchip debug driver for roc-rk3399-pc
boards since we have verified ram in many instances
with respective U-Boot versions.
Adjust the ENV offset, size to fit into all images
on 16MB flash.
Enable DWC3 core, gadget for roc-rk3399-pc board.
This would help to use fastboot by default.
Due to how the Makefile logic is we currently get DM_SPI support in SPL
enabled by having DM_SPI enabled for full U-Boot but not having
CONFIG_SPL_DM_SPI set. Add this missing option to boards that were
inadvertently making use of it.
Cc: Adam Ford <aford173@gmail.com>
Cc: Akash Gajjar <akash@openedev.com>
Cc: Andy Yan <andy.yan@rock-chips.com>
Cc: Anup Patel <anup.patel@wdc.com>
Cc: Atish Patra <atish.patra@wdc.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Chee Hong Ang <chee.hong.ang@intel.com>
Cc: Chin-Liang See <clsee@altera.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Cc: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Klaus Goger <klaus.goger@theobroma-systems.com>
Cc: Levin Du <djw@t-chip.com.cn>
Cc: Ley Foon Tan <ley.foon.tan@intel.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Luca Ceresoli <luca@lucaceresoli.net>
Cc: Mike Looijmans <mike.looijmans@topic.nl>
Cc: Nicolas Ferre <nicolas.ferre@microchip.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Peter Robinson <pbrobinson@gmail.com>
Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Suniel Mahesh <sunil@amarulasolutions.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Wolfgang Grandegger <wg@aries-embedded.de>
Reviewed-by: Luca Ceresoli <luca@lucaceresoli.net>
U-Boot TPL 2020.07-rc3-00090-gd4e919f927-dirty (Jun 01 2020 - 23:45:53)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.07-rc3-00087-ga21e9fd385 (Jun 02 2020 - 00:09:45 +0530)
Trying to boot from MMC1
NOTICE: BL31: v2.2(release):
NOTICE: BL31: Built : 15:05:37, May 12 2020
U-Boot 2020.07-rc3-00087-ga21e9fd385 (Jun 02 2020 - 00:09:45 +0530)
SoC: Rockchip rk3399
Reset cause: POR
Model: Firefly ROC-RK3399-PC Board
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Mark the default U-Boot environment as SPI flash since
this is an on board flash device.
Updated env offset, size in contrast with default since
the U-Boot proper has to start from 384K.
Enable USB3.0 Host support for ROC-RK3399-PC boards.
Tested USB3.0 SSD on Type C1 port on board.
=> usb start
starting USB...
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3c0000: USB EHCI 1.00
Bus dwc3: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
scanning bus usb@fe380000 for devices... 1 USB Device(s) found
scanning bus usb@fe3c0000 for devices... 2 USB Device(s) found
scanning bus dwc3 for devices... 6 USB Device(s) found
scanning usb for storage devices... 1 Storage Device(s) found
=> usb tree
USB device tree:
1 Hub (480 Mb/s, 0mA)
u-boot EHCI Host Controller
+-2 Hub (480 Mb/s, 100mA)
USB 2.0 Hub [MTT]
1 Hub (5 Gb/s, 0mA)
| U-Boot XHCI Host Controller
+-2 Hub (480 Mb/s, 0mA)
| | VIA Labs, Inc. USB2.0 Hub
| +-4 Hub (480 Mb/s, 100mA)
| | USB 2.0 Hub
| +-5 (480 Mb/s, 100mA)
| VIA Technologies Inc. USB 2.0 BILLBOARD 0000000000000001
+-3 Hub (5 Gb/s, 0mA)
| VIA Labs, Inc. USB3.0 Hub
+-6 Mass Storage (5 Gb/s, 224mA)
JMicron External Disk 3.0 DB12345678A2
=> usb reset
resetting USB...
USB XHCI 1.10
Enable PCIe/M.2 support on
- NanoPC-T4
- ROC-RK3399-PC Mezzanine boards.
Tested-by: Suniel Mahesh <sunil@amarulasolutions.com> #roc-rk3399-pc
Add Firefly ROC-RK3399-PC Mezzanine board which is an
extension board on top of roc-rk3399-pc.
Will drop the separate defconfig file, once we support
the board detection at runtime.
Signed-off-by: Suniel Mahesh <sunil@amarulasolutions.com>
