path: root/configs/rastaban_defconfig
2015-06-19siemens,am33x,rastaban: add rastaban configHeiko Schocher
rastaban is a draco version with more flash, more RAM and faster CPU. Number of partitions is the same but rootfs partition is different. Signed-off-by: Samuel Egli <samuel.egli@siemens.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
