path: root/configs/r8a77995_draak_defconfig
2018-10-18ARM: rmobile: Remove console parameter from bootargs on Gen3Hiroyuki Yokoyama
This patch removes 'console=' argument, because kernel uses stdout-path as parameter. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-16ARM: rmobile: Enable RPCHF on DraakMarek Vasut
Enable the Renesas RPC HF driver on R8A77995 D3 Draak. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-17ARM: rmobile: Enable fitImage support on Gen3Marek Vasut
Enable fitImage support to be on the right side of the millenium. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-14ARM: rmobile: Zap CONFIG_MMC_RENESAS_TUNINGMarek Vasut
Drop the CONFIG_MMC_RENESAS_TUNING symbol from Gen3 configs. This symbol is no longer used after the Matsushita SDHI driver, instead the renesas-sdhi driver uses CONFIG_MMC_HS200_SUPPORT to discern whether the tuning support should be compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> -- V2: Submit this on top of configs which are actually in mainline
2018-04-11ARM: rmobile: Enable HS200 mode on RCar Gen3Marek Vasut
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Switch to CONFIG_RENESAS_SDHIMarek Vasut
Since the Renesas SDHI has it's own custom driver sharing the common code with Uniphier one, adjust the Kconfig entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-16ARM: rmobile: Enable DTO support on Gen3Marek Vasut
Enable support for applying DT overlays on Gen3. This is convenient for handling extra additional hardware, like ie. the Kingfisher. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-12-18configs: Resync with savedefconfigTom Rini
2017-12-09ARM: rmobile: Add R8A77995 D3 Draak boardMarek Vasut
Add bits to support yet another board, the R8A77995 D3 Draak. The DT file is from Linux 4.15-rc1 , commit b35334447513c14a4dd55a67c269a743d4a4824b . Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
