path: root/configs/r8a77970_eagle_defconfig
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-21ARM: rmobile: Sync Gen3 defconfigsMarek Vasut
Synchronize R-Car Gen3 defconfigs to remove duplicate pinctrl entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-11-13configs: Resync with savedefconfigTom Rini
2018-10-18ARM: rmobile: Remove console parameter from bootargs on Gen3Hiroyuki Yokoyama
This patch removes 'console=' argument, because kernel uses stdout-path as parameter. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
2018-06-19ARM: rmobile: Adjust text base on V3M EagleMarek Vasut
The latest ATF puts the U-Boot at 0x50000000, just like on all the other boards. Adjust the text base to reflect that change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-16ARM: rmobile: Disable 4k SF sectors on V3M EagleMarek Vasut
The V3M Eagle uses flash with 128 kiB or 256 kiB sectors, disable the 4k sector support. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-06-16ARM: rmobile: Enable cache command on V3M EagleMarek Vasut
Turning the cache off can help when experimenting with bare metal applications, enable the cache command on V3M Eagle to make that easier. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-17ARM: rmobile: Enable fitImage support on Gen3Marek Vasut
Enable fitImage support to be on the right side of the millenium. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-17ARM: rmobile: Disable SDHI on R8A77970 V3M EagleMarek Vasut
The SDHI is not routed to a slot on the Eagle, so disable it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-17ARM: rmobile: Enable RPC QSPI on R8A77970 V3M EagleMarek Vasut
Enable the RPC QSPI driver on R8A77970 V3M Eagle and configure the environment layout to match that used by old U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-14ARM: rmobile: Zap CONFIG_MMC_RENESAS_TUNINGMarek Vasut
Drop the CONFIG_MMC_RENESAS_TUNING symbol from Gen3 configs. This symbol is no longer used after the Matsushita SDHI driver, instead the renesas-sdhi driver uses CONFIG_MMC_HS200_SUPPORT to discern whether the tuning support should be compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> -- V2: Submit this on top of configs which are actually in mainline
2018-04-11ARM: rmobile: Enable HS200 mode on RCar Gen3Marek Vasut
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Switch to CONFIG_RENESAS_SDHIMarek Vasut
Since the Renesas SDHI has it's own custom driver sharing the common code with Uniphier one, adjust the Kconfig entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-16ARM: rmobile: Enable DTO support on Gen3Marek Vasut
Enable support for applying DT overlays on Gen3. This is convenient for handling extra additional hardware, like ie. the Kingfisher. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-12-09ARM: rmobile: Add R8A77970 V3M Eagle boardMarek Vasut
Add bits to support yet another board, the R8A77970 V3M Eagle. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
