path: root/configs/r8a7795_ulcb_defconfig
2019-05-21ARM: rmobile: Add recovery SPL for R-Car Gen3Marek Vasut
Build an SPL which can be started via SCIF download mode on R-Car Gen3 and allows loading and executing U-Boot uImage with the next stage code. This is also useful for starting e.g. ATF BL2, which inits the hardware and returns to the U-Boot SPL, which can then load e.g. U-Boot proper. The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL while the payload, e.g. ATF BL2, executes, so there is no problem here. However, E3 and D3 have much less SRAM, hence the loader uses a trick where it copies itself beyond the area used by BL2 and executes from there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS, stack and malloc area, so the later two are placed at +0x4000 offset from start of SRAM, another area not used by ATF BL2. To make things even more complicated, the SCIF loader cannot load to the upper 32kiB of the SRAM directly, hence the copying approach. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-05-21ARM: rmobile: Sync Gen3 defconfigsMarek Vasut
Synchronize R-Car Gen3 defconfigs to remove duplicate pinctrl entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-04-09ARM: rmobile: Add R8A77965 M3NULCB supportMarek Vasut
Add defconfig and board specific adjustments for the R8A77965 M3N ULCB. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-04-09ARM: rmobile: Enable multi-DTB fit LZO compressionMarek Vasut
Enable LZO compression of the multi-DTB fitImages, since the U-Boot with multiple DTs enabled is becoming quite large and the DTs can be well compressed. The LZO compression saves almost 200 kiB on the Salvator-X(S) and ULCB targets. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-04ARM: dts: Turn ULCB into Multi-DTB configMarek Vasut
Bundle DTBs for R8A7795, R8A7796 ULCB variants into single U-Boot build and let U-Boot choose between them based on the CPU model. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-12-03ARM: rmobile: Enable MMC HS400 on Salvator-X, ULCB, EbisuMarek Vasut
Enable the HS400 support code on H3, M3W, M3N Salvator-X(S) and ULCB boards as well as E3 Ebisu board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-10-18ARM: rmobile: Remove console parameter from bootargs on Gen3Hiroyuki Yokoyama
This patch removes 'console=' argument, because kernel uses stdout-path as parameter. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
2018-04-17ARM: rmobile: Enable fitImage support on Gen3Marek Vasut
Enable fitImage support to be on the right side of the millenium. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-14ARM: rmobile: Zap CONFIG_MMC_RENESAS_TUNINGMarek Vasut
Drop the CONFIG_MMC_RENESAS_TUNING symbol from Gen3 configs. This symbol is no longer used after the Matsushita SDHI driver, instead the renesas-sdhi driver uses CONFIG_MMC_HS200_SUPPORT to discern whether the tuning support should be compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> -- V2: Submit this on top of configs which are actually in mainline
2018-04-11ARM: rmobile: Enable HS200 mode on RCar Gen3Marek Vasut
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Switch to CONFIG_RENESAS_SDHIMarek Vasut
Since the Renesas SDHI has it's own custom driver sharing the common code with Uniphier one, adjust the Kconfig entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-16ARM: rmobile: Enable DTO support on Gen3Marek Vasut
Enable support for applying DT overlays on Gen3. This is convenient for handling extra additional hardware, like ie. the Kingfisher. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Rework the ULCB CPLD driverMarek Vasut
Rework the ULCB CPLD driver and make it into a sysreset driver, since that is what the ULCB CPLD driver is mostly for. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Migrate boards to RCar IIC driversMarek Vasut
Stop using the old ad-hoc SH I2C driver and use the new RCar IIC driver instead. The SH I2C driver should be deprecated and removed eventually. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Use PRR driver on all Gen3 boardsMarek Vasut
Mark the PRR as u-boot,dm-pre-reloc in all Gen3 board DTs as it is needed very early and turn on the CONFIG_SYSCON to allow the PRR driver to bind as a syscon uclass. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Enable xHCI on RCar Gen3 boardsMarek Vasut
Enable the XHCI support on all boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Enable Micrel KSZ90x1 PHY driver on ULCBMarek Vasut
Enable the Micrel KSZ90x1 driver on ULCB, since the board is populated with KSZ9031 and without this driver, the PHY cannot be operated. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-10-10Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-10-04ARM: rmobile: Enable pinconfMarek Vasut
Enable pinconf since it's now implemented and used in the DTs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-28ARM: rmobile: Switch to DM PFC pinmux and GPIO driverMarek Vasut
Enable the PFC pinmux and GPIO drivers and disable the SH GPIO combo driver. This allows the drivers to obtain pinmux and GPIO configuration from DT rather than hard-coding it in board files. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-28ARM: rmobile: Enable DM regulator supportMarek Vasut
Regulators are needed for the MMC framework to let it toggle the SD power. Enable DM regulator support and support for fixed and GPIO regulator. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-28ARM: rmobile: Switch to UniPhier SD driver on Gen3Marek Vasut
The UniPhier SD driver handles the same Matsushita IP as is used in the Renesas RCar SoCs, yet the driver is significantly better than the SH SDHI one. Switch over to the Uniphier driver. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-24ARM: rmobile: Enable GPIO commandMarek Vasut
This command is convenient for manipulating the GPIOs, so enable it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-24ARM: rmobile: Move CONFIG_CMD_ from rcar-gen3-common to configsMarek Vasut
Just move those config options from macros to configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-12ARM: rmobile: Enable EHCI generic on ULCBMarek Vasut
Enable the EHCI generic driver, which is superior to ad-hoc SoC specific one. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-07ARM: rmobile: Disable CONFIG_ARCH_FIXUP_FDT_MEMORYMarek Vasut
Disable CONFIG_ARCH_FIXUP_FDT_MEMORY to prevent U-Boot from modifying the memory {} nodes in the DT passed to the Linux kernel. The R8A779x DT contains multiple memory {} nodes, while U-Boot only modifies the first one and stuffs all the memory entries into it, which is wrong. Disabling CONFIG_ARCH_FIXUP_FDT_MEMORY is the least intrusive way to fix the issue this close to the release, while the real fix is to extend the fdt_fixup_memory_banks() to handle multiple memory nodes in DT. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Enable MMC and USB DM on ULCBMarek Vasut
Enable the MMC and USB DM on the board since it's the modern method and now supported by the drivers. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Enable HUSH parserMarek Vasut
The HUSH parser was disabled somewhere along the way, reenable it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Alexandru Gagniuc <alex.g@adaptrum.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-03ARM: rmobile: Update defconfig of R-Car Gen3Nobuhiro Iwamatsu
This updates defconfig of R-Car Gen3 to keep with the latest Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: rmobile: Enable clock framework on ULCBMarek Vasut
Since there is now a clock driver for RCar Gen3, enable it on this board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: rmobile: Enable OF_CONTROL on RCar Gen3Marek Vasut
Since the DTs are now in place, enable OF control so that they get bundled into the U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: rmobile: ulcb: Add ULCB board supportMarek Vasut
Add initial support for the R8A7795 and R8A7796 based ULCB board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
