path: root/configs/r8a7795_salvator-x_defconfig
2017-06-20ARM: rmobile: Add missing config bitsMarek Vasut
The commit "fb82fe385173 configs: Resync defconfigs" resynced all config files. This exposed two latent issues with the Gen3 boards in that we had not been setting CONFIG_DEFAULT_FDT_FILE correctly and had not been setting CONFIG_CMD_MMC. Fix both of these. Fixes: fb82fe385173 ("configs: Resync defconfigs") Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22ARM: rmobile: salvator-x: Rename the defconfig to match the SoCMarek Vasut
Rename the salvator-x_defconfig to r8a7795_salvator-x_defconfig in preparation for the r8a7796 support on salvator-x board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
