path: root/configs/r8a7795_salvator-x_defconfig
2018-04-17ARM: rmobile: Enable fitImage support on Gen3Marek Vasut
Enable fitImage support to be on the right side of the millenium. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-14ARM: rmobile: Zap CONFIG_MMC_RENESAS_TUNINGMarek Vasut
Drop the CONFIG_MMC_RENESAS_TUNING symbol from Gen3 configs. This symbol is no longer used after the Matsushita SDHI driver, instead the renesas-sdhi driver uses CONFIG_MMC_HS200_SUPPORT to discern whether the tuning support should be compiled in. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> -- V2: Submit this on top of configs which are actually in mainline
2018-04-11ARM: rmobile: Enable HS200 mode on RCar Gen3Marek Vasut
Enable the HS200 on RCar Gen3 platforms, since the SDHI core supports it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Switch to CONFIG_RENESAS_SDHIMarek Vasut
Since the Renesas SDHI has it's own custom driver sharing the common code with Uniphier one, adjust the Kconfig entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-16ARM: rmobile: Enable DTO support on Gen3Marek Vasut
Enable support for applying DT overlays on Gen3. This is convenient for handling extra additional hardware, like ie. the Kingfisher. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: dts: rmobile: Factor out U-Boot extrasMarek Vasut
Pull out u-boot extras into dtsi files to make synchronization of DTS from Linux kernel as easy as a simple copy. All the U-Boot extras are now in *-u-boot.dts* files instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Migrate boards to RCar IIC driversMarek Vasut
Stop using the old ad-hoc SH I2C driver and use the new RCar IIC driver instead. The SH I2C driver should be deprecated and removed eventually. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Use PRR driver on all Gen3 boardsMarek Vasut
Mark the PRR as u-boot,dm-pre-reloc in all Gen3 board DTs as it is needed very early and turn on the CONFIG_SYSCON to allow the PRR driver to bind as a syscon uclass. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Enable xHCI on RCar Gen3 boardsMarek Vasut
Enable the XHCI support on all boards. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-11-30ARM: rmobile: Remove CONFIG_CMD_SDRAM from Salvator-XMarek Vasut
This command is useless on Salvator-X as it is reading DRAM info from SPD. We have no SPD on Salvator-X. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-10-10Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
2017-10-04ARM: rmobile: Enable pinconfMarek Vasut
Enable pinconf since it's now implemented and used in the DTs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-28ARM: rmobile: Switch to DM PFC pinmux and GPIO driverMarek Vasut
Enable the PFC pinmux and GPIO drivers and disable the SH GPIO combo driver. This allows the drivers to obtain pinmux and GPIO configuration from DT rather than hard-coding it in board files. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-28ARM: rmobile: Enable DM regulator supportMarek Vasut
Regulators are needed for the MMC framework to let it toggle the SD power. Enable DM regulator support and support for fixed and GPIO regulator. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-28ARM: rmobile: Switch to UniPhier SD driver on Gen3Marek Vasut
The UniPhier SD driver handles the same Matsushita IP as is used in the Renesas RCar SoCs, yet the driver is significantly better than the SH SDHI one. Switch over to the Uniphier driver. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-24ARM: rmobile: Enable GPIO commandMarek Vasut
This command is convenient for manipulating the GPIOs, so enable it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-24ARM: rmobile: Move CONFIG_CMD_ from rcar-gen3-common to configsMarek Vasut
Just move those config options from macros to configs. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-12ARM: rmobile: Enable EHCI generic on Salvator-XMarek Vasut
Enable the EHCI generic driver, which is superior to ad-hoc SoC specific one. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-09-07ARM: rmobile: Disable CONFIG_ARCH_FIXUP_FDT_MEMORYMarek Vasut
Disable CONFIG_ARCH_FIXUP_FDT_MEMORY to prevent U-Boot from modifying the memory {} nodes in the DT passed to the Linux kernel. The R8A779x DT contains multiple memory {} nodes, while U-Boot only modifies the first one and stuffs all the memory entries into it, which is wrong. Disabling CONFIG_ARCH_FIXUP_FDT_MEMORY is the least intrusive way to fix the issue this close to the release, while the real fix is to extend the fdt_fixup_memory_banks() to handle multiple memory nodes in DT. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Enable MMC and USB DM on Salvator-XMarek Vasut
Enable the MMC and USB DM on the board since it's the modern method and now supported by the drivers. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Enable HUSH parserMarek Vasut
The HUSH parser was disabled somewhere along the way, reenable it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Alexandru Gagniuc <alex.g@adaptrum.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-26ARM: rmobile: Enable KSZ90X1 PHY on Salvator-XMarek Vasut
Commit da3b9e7fd6a1 (Move PHY_MICREL and PHY_MICREL_KSZ90X1 to Kconfig) broke ethernet support on R8A779x Salvator-X boards by disabling the KSZ90x1 PHY in Kconfig. Reenable it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Alexandru Gagniuc <alex.g@adaptrum.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-03ARM: rmobile: Update defconfig of R-Car Gen3Nobuhiro Iwamatsu
This updates defconfig of R-Car Gen3 to keep with the latest Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: rmobile: Enable clock framework on Salvator-XMarek Vasut
Since there is now a clock driver for RCar Gen3, enable it on this board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-08-03ARM: rmobile: Enable OF_CONTROL on RCar Gen3Marek Vasut
Since the DTs are now in place, enable OF control so that they get bundled into the U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-06-20ARM: rmobile: Add missing config bitsMarek Vasut
The commit "fb82fe385173 configs: Resync defconfigs" resynced all config files. This exposed two latent issues with the Gen3 boards in that we had not been setting CONFIG_DEFAULT_FDT_FILE correctly and had not been setting CONFIG_CMD_MMC. Fix both of these. Fixes: fb82fe385173 ("configs: Resync defconfigs") Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22ARM: rmobile: salvator-x: Rename the defconfig to match the SoCMarek Vasut
Rename the salvator-x_defconfig to r8a7795_salvator-x_defconfig in preparation for the r8a7796 support on salvator-x board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
