path: root/configs/r7-tv-dongle_defconfig
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Remove CONFIG_TARGET_FOO for sun5i and sun7i boardsHans de Goede
CONFIG_TARGET_FOO was only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), all sun5i and sun7i boards have been moved over to using a single dram_sun5i_autoconfig file, and the tx clk delay handling for the Banana boards now has its own Kconfig. IOW nothing is using CONFIG_TARGET_FOO anymore, so remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Convert sun5i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun5i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. This has been tested on a A10s-Olinuxino, A13-Olinuxino, A13-OlinuxinoM, mk802-a10s and r7-tv-dongle board. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-13sunxi: ehci: Add proper Kconfig options to select the usb Vbus gpio-sHans de Goede
Add proper Kconfig options to select the usb Vbus gpio-s, besides moving to Kconfig being the right thing to do, an added advantage of this is that it allows for boards without Vbus gpio-s. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD>Ian Campbell
This was done automatically with the following bits of scripting. The Kconfig choice content was generated with this script snippet: for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i); MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i) echo "config TARGET_$TARGET" echo " bool \"$TARGET\"" echo " depends on $MACH" echo done defconfigs were updated with a sed script (t): # Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS, /^CONFIG_SYS_EXTRA_OPTIONS/ { s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/; # Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving # CONFIG_TARGET_<BOARD> in pattern space P;D; }; # Move CONFIG_TARGET_<BOARD> to hold space /^CONFIG_TARGET/{h;n} # Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or # normal mode. /^CONFIG_MACH/{p;g;p;n}; /^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n}; # Print any remaining lines normally p; Run as: sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*) and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from Colombus_defconfig board/sunxi/Makefile was updated with: sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile and manually retabbing a few lines to line up again. The board descriptions could certainly be improved. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I.Ian Campbell
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the future. Done automatically with: sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I) Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add top-level ARCH_SUNXIIan Campbell
And make TARGET_SUN[45678]I a choice variable under this. configs updated with: sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/* Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-09-05sunxi: Correct typo CONFIG_FTDFILE => CONFIG_FDTFILEIan Campbell
Patch is the result of: sed -i -e 's/FTDFILE/FDTFILE/g' board/sunxi/Kconfig configs/* include/configs/sunxi-common.h sed -i -e 's/ftdfile/fdtfile/g' board/sunxi/Kconfig Reported-by: Vagrant Cascadian <vagrant@debian.org> Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> [ ijc -- s/Spotted-by/Reported-by/ and resolve conflict vs "remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONS" ]
2014-09-05kconfig: remove redundant "SPL" from CONFIG_SYS_EXTRA_OPTIONSMasahiro Yamada
CONFIG_SPL is defined as a primary option in Kconfig. It should not be added to CONFIG_SYS_EXTRA_OPTIONS. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-08-12sunxi: Add environment settings to make extlinux.conf booting workHans de Goede
Automatic booting using an extlinux.conf file requires various environment variables to be set. Also modify CONFIG_SYS_LOAD_ADDR and CONFIG_STANDALONE_LOAD_ADDR to match the value chosen for kernel_addr_r, see the added comment for why the new value is chosen. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-07-31sunxi: Enable EHCI on various sunxi boardsHans de Goede
Most sunxi boards have the EHCI controller hooked up, enable it on all relevant boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
