path: root/configs/r2dplus_defconfig
2016-12-02r2dplus: select rtl8139 driver in defconfigVladimir Zapolskiy
CONFIG_RTL8139 was moved to a board defconfig by a commit 86e9dc86b1a2 ("net: Move CONFIG_RTL8139 to Kconfig"), however it was done incorrectly due to a missing CONFIG_NETDEVICES selection, thus virtually it was just a removal of the driver compilation. As an unlucky consequence the option was completely removed by a purge commit adad96e60d0e ("configs: Re-sync HUSH options"), restore the driver inclusion back. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-22net: Move CONFIG_RTL8139 to KconfigBin Meng
Introduce CONFIG_RTL8139 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> [trini: Fixup MPC8641HPCN* and r2dplus configs] Signed-off-by: Tom Rini <trini@konsulko.com>
