path: root/configs/qemu_mips64el_defconfig
2014-11-01MIPS: kconfig: merge targets qemu_mips and qemu_mips64Daniel Schwierzeck
Now the user can separately select the CPU type. Thus the targets qemu_mips and qemu_mips64 can be merged to a single target. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-11-01MIPS: kconfig: add options for endianess selectDaniel Schwierzeck
Add new Kconfig option to let the user select the targets endianess. Each target have to select SUPPORTS_BIG_ENDIAN and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess is supported. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
