Now that PIE works when U-Boot is started from ROM, let's enable
CONFIG_POSITION_INDEPENDENT, which allows to load U-Boot also via
ARM Trusted-Firmware's fip.bin to DRAM, without tweaking the
configuration.
To get a writable initial stack, we need to keep the fixed initial
stack pointer, which points to DRAM in our case.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
For testing automated updates via dfu and mtd we need the dfu and mtd
commands as well as preboot support.
Replace the "pci enum" preboot sequence with CONFIG_PCI_INIT_R=y.
Signed-off-by: Ovidiu Panait <ovidiu.panait@windriver.com>
For testing UEFI FIT images we need FIT image support on QEMU.
CONFIG_MTD must be reserved for the MTD core. Like any other
subsystem, prefix the symbol by DM when it comes to DM support.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Add Kconfig files]
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
To reduce the default image size CONFIG_CMD_NVEDIT_EFI was disabled by
default. Re-enable it on the QEMU platforms supporting the UEFI sub-system.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
Currently on qemu-arm platforms environment is kept in RAM. Instead
use pflash device 1 to provide persistent environment support across
device reset.
Also (optionally) provide support for persistent environment across
qemu machine OFF/ON using following instructions:
- Create envstore.img using qemu-img:
qemu-img create -f raw envstore.img 64M
- Add a pflash drive parameter to the command line:
-drive if=pflash,format=raw,index=1,file=envstore.img
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
This adds a Kconfig file in the board directory, so that some
board-specific options can be specified there.
We should run the EFI selftest on both a 32bit and a 64bit ARM platform on
Travis to catch possible errors.
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
QEMU provides an emulated ARM AMBA PrimeCell PL031 RTC.
The patch sets the base address in the board include file according to the
definition in hw/arm/virt.c of the QEMU source. It defines the Kconfig
option for the existing driver, and enables the RTC driver in
qemu_arm64_defconfig and qemu_arm_defconfig as well as the date command.
We need an RTC to provide the GetTime() runtime service in the UEFI
subsystem.
Reviewed-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
Tested-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
This adds support for '-machine virt' on AArch64. This is rather simple:
we just add TARGET_QEMU_ARM_xxBIT to select a few different Kconfig
symbols, provide the ARMv8 memory map from the board file and add a new
defconfig based on the 32-bit defconfig.
