path: root/configs/qemu_arm64_defconfig
2018-11-14arm: qemu: Add a Kconfig in the board directoryBin Meng
This adds a Kconfig file in the board directory, so that some board-specific options can be specified there. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2018-11-13configs: Resync with savedefconfigTom Rini
2018-09-23efi_selftest: test qemu-arm(64)_defconfigHeinrich Schuchardt
We should run the EFI selftest on both a 32bit and a 64bit ARM platform on Travis to catch possible errors. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexander Graf <agraf@suse.de>
2018-07-19ARM: qemu-arm: enable RTCHeinrich Schuchardt
QEMU provides an emulated ARM AMBA PrimeCell PL031 RTC. The patch sets the base address in the board include file according to the definition in hw/arm/virt.c of the QEMU source. It defines the Kconfig option for the existing driver, and enables the RTC driver in qemu_arm64_defconfig and qemu_arm_defconfig as well as the date command. We need an RTC to provide the GetTime() runtime service in the UEFI subsystem. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Tested-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Signed-off-by: AKASHI Takahiro <takahiro.akashi@linaro.org>
2018-01-19ARM: qemu-arm: Add support for AArch64Tuomas Tynkkynen
This adds support for '-machine virt' on AArch64. This is rather simple: we just add TARGET_QEMU_ARM_xxBIT to select a few different Kconfig symbols, provide the ARMv8 memory map from the board file and add a new defconfig based on the 32-bit defconfig. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi> Reviewed-by: Tom Rini <trini@konsulko.com>
