path: root/configs/qemu-x86_defconfig
2016-06-12x86: Enable regmap and syscon for coreboot and qemu-x86Bin Meng
These are generic and should be turned on on coreboot and qemu-x86. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-05-23cmd: qfw: rename qemu_fw_cfg.[c|h] to qfw.[c|h]Miao Yan
Make file names consistent with CONFIG_QFW and CONFIG_CMD_QFW Signed-off-by: Miao Yan <yanmiaobest@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-23x86: qemu: Move qfw command over to cmd and add Kconfig entryTom Rini
- Move the command portion of arch/x86/cpu/qemu/fw_cfg.c into cmd/qemu_fw_cfg.c - Move arch/x86/include/asm/fw_cfg.h to include/qemu_fw_cfg.h - Rename ACPI table portion to arch/x86/cpu/qemu/acpi_table.c Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-03-17x86: qemu: Enable ACPI table generation by defaultBin Meng
Now that ACPI is supported on QEMU, enable it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-03-14Correct defconfig orderingSimon Glass
Various boards have the wrong Kconfig ordering now. To avoid a misleading diff in the next patch, reorder the configuration correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-01-19vsprintf.c: Always enable CONFIG_SYS_VSNPRINTFTom Rini
Enabling this function always removes some class of string saftey issues. The size change here in general is about 400 bytes and this seems a reasonable trade-off. Cc: Peng Fan <peng.fan@nxp.com> Cc: Peter Robinson <pbrobinson@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Adrian Alonso <aalonso@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-01x86: Convert to use driver model timerBin Meng
Convert all x86 boards to use driver model tsc timer. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model ethBin Meng
Move to driver model for ETH (e1000) on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model usbBin Meng
Move to driver model for USB on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-13x86: qemu: Convert to use driver model pciBin Meng
Move to driver model for pci on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-08-05x86: qemu: Add MP initializationBin Meng
Add a cpu1 node to the device tree and enable the MP initialization on QEMU targets (i440fx and q35). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: qemu: Enable writing MP tableBin Meng
Enable writing MP table for QEMU boads (i440fx and q35). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-07-28x86: Enable DM RTC support for all x86 boardsBin Meng
Add a RTC node in the device tree to enable DM RTC support. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> (Squashed in 'x86: Fix RTC build error on ivybridge')
2015-06-04x86: qemu: Implement PIRQ routingBin Meng
Support QEMU PIRQ routing via device tree on both i440fx and q35 platforms. With this commit, Linux booting on QEMU from U-Boot has working ATA/SATA, USB and ethernet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Create separate i440fx and q35 device treesBin Meng
Although the two qemu-x86 targets (i440fx and q35) share a lot in common, they still have something that cannot easily handled in one single device tree). Split to create two dedicated device tree files and make the i440fx be the default build target. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: qemu: Add graphics supportBin Meng
It turns out that QEMU x86 emulated graphic card has a built-in option ROM which can be run perfectly with native mode by U-Boot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-06-04x86: Support QEMU x86 targetsBin Meng
This commit introduces the initial U-Boot support for QEMU x86 targets. U-Boot can boot from coreboot as a payload, or directly without coreboot. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Merged in patch 'x86: qemu: Add CMD_NET to qemu-x86_defconfig https://patchwork.ozlabs.org/patch/479745/
