path: root/configs/qemu-riscv32_smode_defconfig
2020-08-10configs: Resync with savedefconfigTom Rini
2019-12-03mtd: rename CONFIG_MTD -> CONFIG_DM_MTDMiquel Raynal
CONFIG_MTD must be reserved for the MTD core. Like any other subsystem, prefix the symbol by DM when it comes to DM support. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Add Kconfig files] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-10-17efi_loader: enable CONFIG_CMD_NVEDIT_EFI on QEMUHeinrich Schuchardt
To reduce the default image size CONFIG_CMD_NVEDIT_EFI was disabled by default. Re-enable it on the QEMU platforms supporting the UEFI sub-system. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2019-09-05riscv: qemu: enable CONFIG_CMD_BOOTEFI_SELFTESTHeinrich Schuchardt
Enable CONFIG_CMD_BOOTEFI_SELFTEST for the QEMU RISC-V boards. Travis CI QEMU testing has been enabled for qemu-riscv64_defconfig. With this patch we will test the UEFI sub-system on the board. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-12-05riscv: Add S-mode defconfigs for QEMU virt machineAnup Patel
This patch adds S-mode defconfigs for QEMU virt machine so that we can run u-boot in S-mode on QEMU using M-mode runtime firmware (BBL or equivalent). Signed-off-by: Anup Patel <anup@brainfault.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
