path: root/configs/qemu-riscv32_defconfig
2018-11-26riscv: qemu: enable distro bootLukas Auer
Enable distro boot on the qemu-riscv32/64 boards. Supported boot target devices are VirtIO and DHCP. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2018-11-26riscv: qemu: support booting LinuxLukas Auer
Support booting Linux (as payload of BBL) from FIT images. For this, the default CONFIG_SYS_BOOTM_LEN is increased to 16 MB, and the environment variables fdt_high and initrd_high are set to mark the device tree and initrd as in-place. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-11-26riscv: qemu: use device tree passed by prior boot stageLukas Auer
QEMU provides a device tree, which is passed to U-Boot using register a1. We are now able to directly select the device tree with the configuration CONFIG_OF_PRIOR_STAGE. Replace the hard-coded address in qemu-riscv with it. Signed-off-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
2018-10-03riscv: Add QEMU virt board supportBin Meng
This adds QEMU RISC-V 'virt' board target support, with the hope of helping people easily test U-Boot on RISC-V. The QEMU virt machine models a generic RISC-V virtual machine with support for the VirtIO standard networking and block storage devices. It has CLINT, PLIC, 16550A UART devices in addition to VirtIO and it also uses device-tree to pass configuration information to guest software. It implements RISC-V privileged architecture spec v1.10. Both 32-bit and 64-bit builds are supported. Support is pretty much preliminary, only booting to U-Boot shell with the UART driver on a single core. Booting Linux is not supported yet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
