path: root/configs/puma-rk3399_defconfig
2017-12-18configs: Resync with savedefconfigTom Rini
2017-11-26rockchip: defconfig: puma-rk3399: bypass ADC-based boot_mode checkPhilipp Tomsich
The boot (and fallback/emergency boot) concept for the RK3399-Q7 differs from Rockchip's reference platforms. On the RK3399-Q7, some of this functionality is present in the bootloader itself (and configurable); some is backed in hardware by the Qseven BIOS_DISABLE signal to invoke the final stages of fallbacks (i.e. either an external boot bypassing on-module memories or falling back to the BROM for USB recovery). In summary: the ADC-based boot_mode check does not apply for the RK3399-Q7 and we therefore disable it (in this commit) by setting CONFIG_BOOT_MODE_REG to 0. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-11-26rockchip: defconfig: puma-rk3399: sync up with SPL changes for ATFPhilipp Tomsich
This defconfig update makes use of the new features: * CONFIG_ROCKCHIP_SPL_RESERVE_IRAM is now set to 0, as there is no overlap between the M0 firmware and the ATF (we load this to DRAM and relocate it to its final location within the ATF) * tracks the ATF_SUPPORT -> ATF renaming Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-11-01rockchip: puma-rk3399: defconfig: select PHY_MICREL_KSZ90X1Philipp Tomsich
The RK3368-uQ7 uses a KSZ9031 PHY on-module. Enable PHY_MICREL_KSZ90X1 in the associated defconfig (this somehow got lost with da3b9e7f). References: da3b9e7f ("Move PHY_MICREL and PHY_MICREL_KSZ90X1 to Kconfig") Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-01rockchip: defconfig: puma-rk3399: update for DM_REGULATOR support in SPLPhilipp Tomsich
The RK3399-Q7 requires DM regulator support in SPL, so we can use the regulator framework to reenable the eMMC and SPI, if these had been turned of by the BIOS_DISABLE signal. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-18rockchip: defconfig: puma-rk3399: enable OF_LIVE (live tree)Philipp Tomsich
With the critical drivers ready for switching to a live tree, we can now enable it in the defconfig for the RK3399-Q7. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate USB Ethernet adapters to KconfigChris Packham
This migrates ASIX, ASIX88179, MCS7830, RTL8152 and SMSC95XX to Kconfig. Update defconfigs. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-09-08usb: net: migrate CONFIG_USB_HOST_ETHER to KconfigChris Packham
CONFIG_USB_HOST_ETHER is the framework that the drivers are dependent on USB_HOST_ETHER. Use this as a menu and move the existing LAN75XX and LAN78XX options under new menu. Finally update the defconfigs that need CONFIG_USB_HOST_ETHER. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-06-07rockchip: defconfig: puma-rk3399: enable SPL_BOARD_INITPhilipp Tomsich
For the RK3399-Q7, we need spl_board_init to be called during SPL startup to set up the pinmux for the debug UART. Enable SPL_BOARD_INIT via defconfig to ensure this function is in fact called. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-06-07rockchip: dts: rk3399-puma: refactor and rename (default) DDR3-1600 DTSPhilipp Tomsich
To better support different RAM timings (DDR3-1333 and DDR3-1866 are assembly options for the RK3399-Q7), this refactors the DTS support and renames the default DTS variant from rk3399-puma to rk3399-puma-ddr1600: - changes the rk3399-puma DTS into a board-specific DTSI by removing the inclusion of the DRAM timings - adds a new rk3399-puma-ddr1600.dts, which includes the (new) common board DTSI and the DDR3-1600 timing DTSI - wires this up from arch/arm/dts/Makefile and configs/puma-rk3399_defconfig Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: defconfig: puma-rk3399: update defconfig with video-supportPhilipp Tomsich
With HDMI output for the RK3399 working, this update the RK3399-Q7 (Puma) defconfig for the new functionality: 1. enables PMIC command (to check if the HDMI voltages are correct) +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y 2. enables video-output (via HDMI) +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y 3. turns on the 'dcache'-command (for a dcache flush) for our QA to fill the framebuffer using 'mw.l' +CONFIG_CMD_CACHE=y 4. turns on the 'bmp'-command +CONFIG_CMD_BMP=y Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: defconfig: puma-rk3399: do not filter clock-names for SPLPhilipp Tomsich
For the RK3399-Q7 module, we use full OF_CONTROL (i.e. not OF_PLATDATA) for SPL. In this configuration, the rockchip_dw_mmc driver retrieves one of its clocks via clk_get_by_name and fails if this is not possible. For this reason, we can not filter clock-names from the device-tree nodes used for the configuration of the SPL stage. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: defconfig: puma-rk3399: enable I2CPhilipp Tomsich
The RK3399-Q7 exposes I2C on its edge connector and uses it as one of the interfaces towards the on-module STM32 (for the emulated RTC and fan-controller). Enable I2C and CMD_I2C support in the defconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: defconfig: puma-rk3399: enable CONFIG_PHY_MICREL_KSZ9031Philipp Tomsich
The RK3399-Q7 has a KSZ9031 GbE PHY. Enable support for it in defconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: defconfig: puma-rk3399: enable RK808 supportPhilipp Tomsich
On the RK3399-Q7, we need PMIC support (for the RK808) to enable HDMI output, as one of the required powerrails is not enabled on boot. For this, we need to enable the RK808 driver. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Version-changes: 3 - With the recent upstream changes to the RK808 (PMIC) driver, the associated configuration options have been renamed to RK8XX. Track this change in the RK3399-Q7 defconfig. Reviewed-by: Simon Glass <sjg@chromium.org>
2017-06-07rockchip: board: puma_rk3399: build FIT image via u-boot.itbPhilipp Tomsich
2017-06-07rockchip: defconfig: puma-rk3399: enable RK3399 efuse driverPhilipp Tomsich
With everything in place (i.e. the new efuse driver, the clk-support for the non-secure efuse block, and the board-specific functions to derive 'serial#' from the cpu-id within the efuses), enable this in the RK3399-Q7 defconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-27pinctrl: Kconfig: sort pinctrl config options to prevent future clutterPhilipp Tomsich
This originally started out as "pinctrl: Kconfig: reorder to keep Rockchip options together" and tried to keep the Rockchip-related config options together. However, we now rewrite all chip-specific driver selections to start with CONFIG_PINCTRL_ (with the inadvertent changes to related Makefiles) and sort those alphabetically. And as this already means touching most of the file, we also reformat the help text to not exceed 80 characters (but make full use of those 80 characters). Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org>
2017-04-15rockchip: ARM64: split RK3399-Q7 board off the RK3399-EVB boardKlaus Goger
The RK3399-Q7 SoM is a Qseven-compatible (70mm x 70mm, MXM-230 connector) system-on-module from Theobroma Systems, featuring the Rockchip RK3399. It provides the following feature set: * up to 4GB DDR3 * on-module SPI-NOR flash * on-module eMMC (with 8-bit interace) * SD card (on a baseboad) via edge connector * Gigabit Ethernet w/ on-module Micrel KSZ9031 GbE PHY * HDMI/eDP/MIPI displays * 2x MIPI-CSI * USB - 1x USB 3.0 dual-role (direct connection) - 2x USB 3.0 host + 1x USB 2.0 (on-module USB 3.0 hub) * on-module STM32 Cortex-M0 companion controller, implementing: - low-power RTC functionality (ISL1208 emulation) - fan controller (AMC6821 emulation) - USB<->CAN bridge controller Note that we use a multi-payload FIT image for booting and have Cortex-M0 payload in a separate subimage: we thus rely on the FIT image loader to put it into the SRAM region that ATF expects it in. Signed-off-by: Klaus Goger <klaus.goger@theobroma-systems.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Fixed build warning on puma-rk3399: Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-04defconfig: puma-rk3399: add defconfig for the RK3399-Q7 (Puma)Philipp Tomsich
This commit adds the baseline defconfig for the RK3399-Q7 (Puma) SoM (under the name 'puma-rk3399_defconfig') featuring the Rockchip RK3399 in a Qseven compatible module. This subsumes the following changes: * defconfig: rk3399: migrate CONFIG_SPL_LIBCOMMON_SUPPORT/CONFIG_SPL_LIBGENERIC_SUPPORT * defconfig: rk3399-puma: add CONFIG_MMC_DW_ROCKCHIP * defconfig: rk3399-puma: disable CONFIG_SPL_OF_PLATDATA * defconfig: rk3399-puma: don't USE_TINY_PRINTF * defconfig: rk3399-puma: set up CONFIG_SYS_BOARD for the RK3399-Q7 * defconfig: rk3399-puma: enable the multi-image loading via CONFIG_SPL_FIT * defconfig: rk3399-puma: SPL should be able to boot from MMC/SD card * defconfig: rk3399-puma: enable GMAC support * defconfig: rk3399-puma: enable support for SPI and Winbond SPI flash * defconfig: rk3399-puma: enable SPI as a boot-source in SPL * defconfig: rk3399-puma: disallow non-FIT images from being loaded * defconfig: rk3399-puma: rename to puma-rk3399 * rockchip: config: rk3399: update defconfigs and rk3399_common For the RK3399-Q7, we want a default boot-order of SPI -> MMC -> uSD. This both follows how the BootROM probes devices and is a sane default for customers in device-personalisation (e.g. it allows for quick and easy factory programming of unpersonalised devices using an SD card) and field usage (with customer devices expected to have their firmware either in SPI or MMC). However, when probing multiple interfaces (according to the result from the board_boot_order function), we need to ensure that only valid FIT images are considered and disable the fallback to assuming that a raw (binary-only) U-Boot image is loaded (to avoid hangs/crashes from jumping to random content loaded from devices that are probed, but don't contain valid image content). By disabling the SPL_RAW_IMAGE_SUPPORT and SPL_LEGACY_IMAGE_SUPPORT options, we ensure that raw images (indistinguishable from random data) are not considered for booting. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Simon Glass <sjg@chromium.org> Drop CONFIG_DEBUG_UART_BOARD_INIT: Signed-off-by: Simon Glass <sjg@chromium.org>
