path: root/configs/porter_defconfig
2019-05-14net: phy: micrel: Allow KSZ8xxx and KSZ90x1 to be used togetherJames Byrne
Commit d397f7c45b0b ("net: phy: micrel: Separate KSZ9000 drivers from KSZ8000 drivers") separated the KSZ8xxx and KSZ90x1 drivers and warns that you shouldn't select both of them due to a device ID clash between the KSZ9021 and the KS8721, asserting that "it is highly unlikely for a system to contain both a KSZ8000 and a KSZ9000 PHY". Unfortunately boards like the SAMA5D3xEK do contain both types of PHY, but fortunately the Linux Micrel PHY driver provides a solution by using different PHY ID and mask values to distinguish these chips. This commit contains the following changes: - The PHY ID and mask values for the KSZ9021 and the KS8721 now match those used by the Linux driver. - The warnings about not enabling both drivers have been removed. - The description for PHY_MICREL_KSZ8XXX has been corrected (these are 10/100 PHYs, not GbE PHYs). - PHY_MICREL_KSZ9021 and PHY_MICREL_KSZ9031 no longer select PHY_GIGE since this is selected by PHY_MICREL_KSZ90X1. - All of the relevant defconfig files have been updated now that PHY_MICREL_KSZ8XXX does not default to 'Y'. Signed-off-by: James Byrne <james.byrne@origamienergy.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-03-09ARM: rmobile: Convert Gen2 Stout, Porter, Silk to DM_SPI{,_FLASH}Marek Vasut
Enable DM_SPI and DM_SPI_FLASH in U-Boot on H2 Stout, M2W Porter and E3 Silk. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-02-25ARM: rmobile: Convert Gen2 to OF_SEPARATEMarek Vasut
Convert R-Car Gen2 from OF_EMBED to OF_SEPARATE, thus getting rid of one of the deprecation warnings. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2019-02-07configs: Don't use SPI_FLASH_BAR as defaultVignesh R
Now that new SPI NOR layer uses stateless 4 byte opcodes by default, don't enable SPI_FLASH_BAR. For SPI controllers that cannot support 4-byte addressing, (stm32_qspi.c, fsl_qspi.c, mtk_qspi.c, ich.c, renesas_rpc_spi.c) add an imply clause to enable SPI_FLASH_BAR so as to not break functionality. Signed-off-by: Vignesh R <vigneshr@ti.com> Tested-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Tested-by: Stefan Roese <sr@denx.de> Tested-by: Horatiu Vultur <horatiu.vultur@microchip.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com> #zynq-microzed
2018-11-13configs: Resync with savedefconfigTom Rini
2018-07-22Convert CONFIG_MTD_PARTITIONS et al to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_MTD_PARTITIONS CONFIG_MTD_DEVICE Signed-off-by: Adam Ford <aford173@gmail.com>
2018-06-01ARM: rmobile: Represent SF partitioning with mtdparts on PorterMarek Vasut
Add mtdparts description for the board. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-05-02ARM: rmobile: Convert CONFIG_ARCH_RMOBILE_BOARD_STRING to KconfigMarek Vasut
Convert the symbol to Kconfig, no functional change. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-13ARM: rmobile: Convert TPL to SPLMarek Vasut
There is currently no use for building the SPL anymore, since the SPI loader can easily be replaced by TPL and TPL does load U-Boot directly. Upgrade TPL to SPL and replace what used to be SPL with it. This way we build the U-Boot sources only twice, not thrice. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-13ARM: rmobile: Shrink the TPLMarek Vasut
Shrink the TPL by using tiny printf and tiny memset by default. This removes the biggest symbol -- vsnprintf_internal -- from the TPL and reduces the text segment by about 2 kiB. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Switch to CONFIG_RENESAS_SDHIMarek Vasut
Since the Renesas SDHI has it's own custom driver sharing the common code with Uniphier one, adjust the Kconfig entries. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-04-11ARM: rmobile: Enable HUSH on M2 PorterMarek Vasut
Enable the HUSH shell, since it is far more capable. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Add JTAG recovery support for M2 PorterMarek Vasut
Add JTAG recovery support into the M2 Porter TPL. This allows the TPL to be loaded over JTAG, initialize the system, wait for the JTAG debugger to load U-Boot image into RAM and then resume and start U-Boot from RAM. The procedure is as follows: 1) Load u-boot-tpl.bin to 0xe6300000 2) Write magic number 0x1337c0de to 0xe6300020 TPL checks for this particular magic and starts JTAG recovery if this number is present. This is not present by default. 3) Start U-Boot TPL from 0xe6300000 4) Wait for a message from TPL on UART indicating JTAG boot: "JTAG boot detected!" 5) Halt the system in JTAG debugger 6) Load U-Boot image (u-boot.img) to 0x4fffffc0 7) Write magic number 0xb33fc0de to 0xe6300024 TPL checks for this particular magic to verify that the U-Boot image was loaded into DRAM by the JTAG debugger. 8) Resume the system in JTAG debugger Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11ARM: rmobile: Add TPL support on R8A7791 M2 PorterMarek Vasut
Add and enable TPL on M2 Porter. The TPL must fit into 16 kiB due to the Gen2 BootROM restriction. The TPL is running from MERAM and is capable of performing the initial initialization of PFC, Clock, GPIO, LBSC, DBSC and QSPI NOR. DBSC is responsible for bringing up the DDR DRAM access. The TPL is capable of loading the next stage, U-Boot, from either SPI NOR or UART as a fallback. If either does provide a valid U-Boot uImage, the system stops, which allows the operator to load U-Boot ie. via JTAG and start it manually. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-04-11spl: spi: Move CONFIG_SPL_SPI_LOAD to KconfigMarek Vasut
Add Kconfig entry for CONFIG_SPL_SPI_LOAD symbol and move all configurations using it to Kconfig. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Tom Rini <trini@konsulko.com>
2018-02-17ARM: rmobile: Replace SH I2C with IIC on PorterMarek Vasut
Get rid of the SH I2C driver on Porter and enable the IIC driver instead . The old SH I2C is completely broken on Porter anyway and the DM/DT capable IIC driver allows access to the PMIC too. Use the DM/DT capable driver instead. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-02-17ARM: rmobile: Enable convenient commands on PorterMarek Vasut
Enable cache and time commands, which are convenience tools for doing benchmarks and various boot tests. Also enable FIT support for booting fitImage. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-02-16ARM: rmobile: Convert Porter to SPLMarek Vasut
Due to size limitations of the MERAM, switch U-Boot to SPL. The SPL is loaded by the SPI_LOADER into MERAM and then loads U-Boot proper into DRAM. This way U-Boot can freely grow in size in DRAM, as there is plenty of it. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> --- NOTE: To update U-Boot, first install u-boot.img to 0x140000 in SPI NOR, then use the Minimon to flash u-boot-spl.srec using ls,2,e6304000. To generate u-boot-spl.srec, use objcopy: arm-linux-gnueabi-objcopy -O srec spl/u-boot-spl u-boot-spl.srec
2018-02-13spi: Migrate CONFIG_SH_QSPI to KconfigTuomas Tynkkynen
2018-01-27ARM: rmobile: Convert R8A7791 Porter board to DM and DTMarek Vasut
Convert the R8A7791 Porter board to DM and DT. This implies mostly enabling the necessary configuration options and plucking out the ad-hoc configuration from the board file. Moreover, the pre-reloc malloc size was increased to allow the clock driver to start up early without running out of malloc space and the early stack was moved further up in the DRAM to avoid rewriting U-Boot itself. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-27ARM: rmobile: Enable OF_CONTROL on RCar Gen2Marek Vasut
Since the DTs are now in place, enable OF control so that they get bundled into the U-Boot. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-24ARM: rmobile: Convert CONFIG_R8A77xx to KconfigMarek Vasut
Convert these configuration options to Kconfig, update board defconfigs and drop them from whitelist. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2018-01-15net: sh-eth: Add to Kconfig and convertNobuhiro Iwamatsu
This adds SH_ETHER to drivers/net/Kconfig and convert to Kconfig. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-07Move PHY_MICREL and PHY_MICREL_KSZ90X1 to KconfigAlexandru Gagniuc
2017-08-03serial: sh: Convert to KconfigMarek Vasut
Convert the SH Serial to Kconfig using tools/moveconfig.py tool and a bit of manual adjustment to cater for failed conversions. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2017-04-08arm: rmobile: Remove default value of Kconfig from defconfigNobuhiro Iwamatsu
This removes CONFIG_BOOTSTAGE_USER_COUNT, CONFIG_BOOTSTAGE_STASH_ADDR and CONFIG_BOOTSTAGE_STASH_SIZE from defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche - Salvator-x Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Update defconfigNobuhiro Iwamatsu
This updated defconfig following boards: - Alt - Gose - Koelsh - Lager - Porter - Silk - Stout - Blanche Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
