path: root/configs/pine64_plus_defconfig
2016-07-31sunxi: Re-enable h3 emac supportHans de Goede
With the recent bug fixes for the sun8i_emac driver all known issues are resolved, so we can re-enable the driver. While at it, also enable the emac on the Orange Pi One. Cc: Chen-Yu Tsai <wens@csie.org> Cc: Corentin LABBE <clabbe.montjoie@gmail.com> Cc: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Jagan Teki <jteki@openedev.com>
2016-07-27sunxi: Disable sun8i emac driverHans de Goede
Disable the sun8i emac driver for now, there are 2 issues with it: 1) It is causing issues with network connectivity under the kernel driver, when booting the kernel with v2 of Corentin's sun8i-h3 emac driver, I get the connection status bouncing between connected at 100mbps full-duplex and being down every second. The second issue is that when trying to use it from u-boot I get a number of unaligned cache flush errors: => dhcp BOOTP broadcast 1 BOOTP broadcast 2 CACHE: Misaligned operation at range [7bf594a8, 7bf59628] BOOTP broadcast 3 CACHE: Misaligned operation at range [7bf59c90, 7bf59e10] CACHE: Misaligned operation at range [7bf5a478, 7bf5a5f8] DHCP client bound to address 10.42.43.80 (1009 ms) Cc: Chen-Yu Tsai <wens@csie.org> Cc: Corentin LABBE <clabbe.montjoie@gmail.com> Cc: Amit Singh Tomar <amittomer25@gmail.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-07-15net: Add EMAC driver for H3/A83T/A64 SoCs.Amit Singh Tomar
This patch add EMAC driver support for H3/A83T/A64 SoCs. Tested on Pine64(A64-External PHY) and Orangepipc(H3-Internal PHY). BIG Thanks to Andre for providing some of the DT code. Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-06-06arm/arm64: implement a boot header capabilityAndre Przywara
Some SPL loaders (like Allwinner's boot0, and Broadcom's boot0) require a header before the actual U-Boot binary to both check its validity and to find other data to load. Sometimes this header may only be a few bytes of information, and sometimes this might simply be space that needs to be reserved for a post-processing tool. Introduce a config option to allow assembler preprocessor commands to be inserted into the code at the appropriate location; typical assembler preprocessor commands might be: .space 1000 .word 0x12345678 Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Steve Rae <srae@broadcom.com> Commit Notes: Please note that the current code: start.S (arm64) and vectors.S (arm) already jumps over some portion of data already, so this option basically just increases the size of this region (and the resulting binary). For use with Allwinner's boot0 blob there is a tool called boot0img[1], which fills the header to allow booting A64 based boards. For the Pine64 we need a 1536 byte header (including the branch instruction) at the moment, so we add this to the defconfig. [1] https://github.com/apritzel/pine64/tree/master/tools END Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25arm64: Pine64: update FDT filesAndre Przywara
The originally committed .dts files for the Pine64 were from an early proof-of-concept version and should have never been committed upstream. Replace them with much more mature versions, which also use a different naming scheme. Please note that at this point there is at least one binding which has not been agreed upon, so this is subject to change. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-04-01sunxi: Add Pine64+ supportSiarhei Siamashka
The Pine64+ is a system based on the Allwinner A64 SoC. It is capable of running AArch64 code and thus is the first of its kind for the sunxi target. This patch adds a defconfig and device tree chunks for it. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> [agraf: Change patch description] Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
