path: root/configs/pico-imx7d_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-05-01Merge tag 'u-boot-imx-20190426' of git://git.denx.de/u-boot-imxTom Rini
Porting to DM and i.MX8 ------------------------ - warp7 to DM - kp_imx53 to DM - Warnings in DT - MX8QM support - colibri-imx6ull to DM - imx7d-pico to DM - ocotp for MX8
2019-04-25pico-imx7d: Convert DM MMCJoris Offouga
This patch enable convert DM MMC for imx7d-pico board and variant. Before the DM conversion only usdhc3 was enabled and therefore it appeared as MMC 0 to u-boot. After enabling MMC DM though usdhc3 defaults to MMC 2, which left unattended would drive changes to existing pico-pi bootscripts and environment variables that rely on mmc 0. Setup the alias of mmc0 and usdhc3 so that existing pico-imx7d boot code will work unmodified. When converting to DM_MMC it is necessary that SPL initializes eMMC by itself, so move the original eMMC initialization from U-Boot proper to SPL. Signed-off-by: Joris Offouga <offougajoris@gmail.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-04-25pico-imx7d: defconfig Enable DM gpio pinctrl and pinctrl_imx7Joris Offouga
This patch is necessary for convert this board to dm driver model DM GPIO requires gpio_request() to be called explicitly before doing any gpio operation Signed-off-by: Joris Offouga <offougajoris@gmail.com>
2019-04-25pico-imx7d: defconfig: Add DT file hooksJoris Offouga
This patch adds DT file hooks for Pico i.MX7D SOM and variant boards Signed-off-by: Joris Offouga <offougajoris@gmail.com>
2019-01-28pico-imx7d: Add LCD supportFabio Estevam
Add support for the VXT VL050-8048NT-C01 panel connected through the 24 bit parallel LCDIF interface. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2019-01-10Kconfig: rename CONFIG_SPL_USB_GADGET_SUPPORT as CONFIG_SPL_USB_GADGETJean-Jacques Hiblot
The SPL option for USB gadget should be named after the option for u-boot (CONFIG_USB_GADGET) Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
2019-01-07configs: Resync with savedefconfigTom Rini
2018-10-09pico-imx7d: Make SPL binary fit into 64kBFabio Estevam
Currently SPL binary is larger than 64kB, which is larger than CONFIG_SPL_MAX_SIZE defined in imx7_spl.h. This causes boot failure on the pico-mx7 targets. Remove CONFIG_SPL_LIBDISK_SUPPORT option for now, so that the SPL binary can fit into the 64kB range. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Enable auxiliary code supportOtavio Salvador
This enables the "bootaux" command so a firmware can be loaded inside the M4 MCU. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Allow default fdtfile to be overridden by defconfigOtavio Salvador
This allow the addition of extra default configurations for each baseboard, removing the boot menu when user boots for the first time. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Enable CONFIG_ARMV7_BOOT_SEC_DEFAULTFabio Estevam
Currently the CAAM driver fails to be probed: caam 30900000.caam: Entropy delay = 3200 caam 30900000.caam: failed to acquire DECO 0 caam 30900000.caam: failed to instantiate RNG CAAM needs to be initialized in secure world, so enable CONFIG_ARMV7_BOOT_SEC_DEFAULT to allow the driver to probe successfully. Tested with kernel mainline version 4.17.2. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Add Falcon mode supportFabio Estevam
Falcon mode boots the kernel directly from SPL, without loading the full U-Boot. As pico-imx7d does not have a GPIO for selecting Falcon versus normal mode, enter in Falcon mode when the customer selects the CONFIG_SPL_OS_BOOT option in menuconfig. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Add bootmenu to choose the baseboardOtavio Salvador
Currently the baseboards do not offer a way to autodetect which one is in use, so we ask the user if no value has been set. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Add SPL supportFabio Estevam
Convert pico-imx7d to SPL support. There are two variants of pico-imx7d SOMs: - One with 512MB of RAM - One with 1GB of RAM The 512MB module contains two Hynix H5TC2G63GFR-PBA. The 1GB module contains two Hynix H5TC4G63GFR-PBA. The RAM size is determined in runtime by reading GPIO1_12. While at it, also add USB Serial Download mode support as it is very helpful for loading SPL and u-boot.img via imx_usb_loader. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Add fastboot supportFabio Estevam
fastboot tool is a convenient way to flash the eMMC, so add support for it. Examples of usages: On the pico-imx7d U-Boot prompt: => fastboot 0 On the Linux PC connected via USB: 1. Retrieving the U-Boot version $ sudo fastboot getvar bootloader-version -i 0x0525 bootloader-version: U-Boot 2018.07-rc1-03888-gde846f9 finished. total time: 0.000s 2. Resetting the board $ sudo fastboot reboot -i 0x0525 (this causes the pico-imx7d to reboot) Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Add default DFU targetsOtavio Salvador
2018-07-23pico-imx7d: Add GPT partitioning supportOtavio Salvador
This allow the use of: > run setup_emmc inside of the U-Boot prompt to do the partitioning of the disk. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-07-23pico-imx7d: Fix common distro configuration behaviorOtavio Salvador
This sets DISTRO_CONFIG and BOOTCOMMAND, as well as add a `finduuid` environment helper to allow it to properly work with Yocto Project and other distributions using extlinux autogenerated configuration files. Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-04-15Merge git://git.denx.de/u-boot-imxTom Rini
2018-04-15pico-imx7d: Replace fatload commandVanessa Maegima
Replace fatload with the fs generic loading interface ('load' command). Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-10-03usb: gadget: Make g_dnl USB settings commonMaxime Ripard
The g_dnl USB settings for the vendor ID, product ID and manufacturer are actually common settings that can and should be shared by all the gadgets. Make them common by renaming them, and convert all the users. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Lukasz Majewski <lukma@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-07-10configs: Resync defconfigsTom Rini
2017-05-31pico-imx7d: Add initial supportVanessa Maegima
Add the initial support for pico-imx7d board based on Wig Cheng's source code. Add support for eMMC, USB gadget, I2C, PMIC and Ethernet. For more information about this board, please visit: http://www.technexion.org/products/pico/pico-som/pico-imx7-emmc Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
